New! Dark mode!
(Topic ID: 257283)
night rider
By willie0912
10 months ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 10 months ago by willie0912
#1 10 months ago
I have a night rider that at start up will not advance the bonus unit to the 1000 position as it is supposed to do, as a result the machine keeps resetting the drop targets and the coil that shoots the ball to the shooter lane keeps firing, any ideas. Also the flippers and pop bumpers died, any ideas would help, Thanks Bill
#2 10 months ago
Solenoid fuse may be blown. Also check the ball outhole trough switch is not stuck closed.
#3 10 months ago
Thanks I'll check that tomorrow when I get back to it.
#4 10 months ago
What's the Outhole relay doing when this happens?
#5 10 months ago
wwWell if the switch is stuck closed than the game thinks the ball fell back and did not make it to the plunger so it keeps trying to kick it out. Now the drop targets resetting also makes me question if this is the case but being an EM it might be designed that way, they reset with each new ball, not sure they trigger with each kick of the trough solenoid. I can check on my game later but this is where I would look first.
#6 10 months ago
Reached thru coin door and held trough switch down and started game...it continually resets bonus counter, drop targets and trough solenoid fires...keeps repeating that routine every couple seconds. Does that sound like what your is doing? Of course there could be a switch on a relay or elsewhere causing the same effect but first things first.
#7 10 months ago
No the outhole switch is not stuck and the outhole relay keeps kicking in and out. Yes it resets drop targets and fires trough coil and score motor runs all the time. I have had some other input on other relays that run in the same series so I have a lot of checking to do. I will Keep you informed, Thanks
#8 10 months ago
I think there is a “player unit” stepper in backbox...could be that not resetting...does ball 1 light on backbox light up when you try to start a game?
#9 10 months ago
Thanks Willie0912!!
#10 10 months ago
Good luck with the Night Rider ! Just finished one . Love the game
Ron Kruzman playfield
729A65DE-9479-427F-9A69-E7A70781985E (resized).jpeg82B71C0B-0DF6-448E-9ABB-E742FDDA8238 (resized).jpeg9C64168C-1059-4C2F-A226-7047370CC95C (resized).jpeg
#11 10 months ago
If the Bonus Unit Stepup solenoid doesn't activate when the Outhole relay does, Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
#12 10 months ago
Thank you for saving my sanity, I never thought it was a voltage problem at the coil I was just looking for the switch circuit problem, turns out I traced the circuit you outlined in red and found that the jones plug was bad at the connection from the tilt relay to the bonus step up coil, I had to change bottom half of jones plug and now all is fine, Thanks again, Bill
Third Coast Pinball
$ 76.95
$ 8.00
Third Coast Pinball
$ 5.00
775
Cleveland, OH
$ 5.00
$ 24.99
Lee's Parts
Docent Electronics
$ 14.95
Filament Printing
$ 1,099.00
$ 209.00
CzTV Mods
$ 7.95
Arcade Upkeep
$ 1,099.00
$ 159.99
$ 29.95
