Got a night moves and it seems the outhole solenoid holds open too long. When 2 balls drain together the outhole solenoid opens long enough to allow both balls into the trough.. this allows the outhole optic to be closed and the game thinks there is only one ball. In this situation the game will not attempt to kick the ball into the shooter lane. If you break the outhole optic beam the game will kick the ball into the shooter lane and all is fine. The problem is if you get a double drain in multiball or lose last ball and a ball is in the lock both balls end up in the outhole at the same time. Then the outhole solenoid fires and holds long enough to put both balls in the trough and the game cannot continue. In solenoid test mode i can put both balls in the outhole and when the solenoid fires it is quick and only allows one ball to go in the trough. Is there a way to adjust the time the solenoid stays energized in game mode to solve this issue?
