(Topic ID: 286257)
NIB MB SE - flippers not working!?
By Richard-NBA-SF2
4 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 4 months ago by Richard-NBA-SF2
#1 4 months ago
Just unboxed this NIB MB , the flippers do not work during game play. Opened the coin door, they work to scroll thru the menu.
Thoughts?
#2 4 months ago
Do any of the coils work in test ? If not go over the wiring to the high power interlock switch. Then check the fuse on the driver board in the head. Manual will help figure out which one.
Also check under the playfield and in the backbox for any connector not plugged in.
You could also pull out the high power interlock switch ( top fat white one on the left right inside the big hole for the coin door ) if the coils work then, then the flap on the coin door isn't pressing the high power interlock switch in far enough.
Quoted from Richard-NBA-SF2:
Thoughts?
That just means the flipper button opto switches are working. Just not the coils.
#3 4 months ago
There was a harness in the back glass not plugged in. I assumed that was for a upgrade or something. Will send a pic tomorrow !
Quoted from LTG:
