(Topic ID: 212879)
Iron Maiden Revealed
By Concretehardt
6 years ago
  • 7,177 posts
  • 673 Pinsiders participating
  • Latest reply 3 years ago by thewool
  • Topic is favorited by 80 Pinsiders
22 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7,177 posts in this topic. You are on page 136 of 144.
#6751 5 years ago
New Stern pro video just gone up on facebook.
https://www.facebook.com/sternpinball?v=wall
#6752 5 years ago
Quoted from thunderking50:
I printed and laminated the Pro and Premium backglass
And made them apron cards
I also did this on Metallica
I'll take a set for both please,lol.
#6753 5 years ago
I am having a problem on my LE, the switch at the bottom of the sarcophagus scoop(when the ramp raises up) is not registering. When I first went in after a handful of games I noticed the metal tab on the switch had been busted off, I got it all put back together but one of the screws that hold that switch in place was missing as well(not sure if this was something Stern missed or intentional to position it). When I get it all back in place where it appears it is supposed to be it won't register the ball in there. Switch tests fine, just not registering with a ball, SO frustrated. Anyone have similar problem or advice, I have tried 20 times to position it different and just no luck.
#6754 5 years ago
Quoted from bemmett:
Yes i played with the metal plate of the switch for a long time before getting the perfect angle to register in upper position and in level position.
Gotta play with that little metal plate
#6755 5 years ago
Not sure what you mean? You are talking about the metal tab part of the switch that presses and registers? It seems in looking at it the only way that switch tab registers is having it over the coil that fires to launch it out(and kind of what I am guessing knocked the metal tab piece off my switch originally)
#6756 5 years ago
Does the switch mount even on this metal piece of the under sarcophagus scoop where both the screws would go(again I only have one screw in mine). If so I can't get it to register. That metal arm is not registering a ball in there.
#6757 5 years ago
If its switch 40 its the switch under the plastic mummy ...take the 4 screw out put the game in diag then IM game test and choose Lock Test , then adjust the metal plate with switch 40 on your screen and you can also move the sarcaphacus in all angle in the test mode
Hope this helps
#6758 5 years ago
Anyone have any good custom instruction cards?
I have this one
4cab5e20bb664ce367dc7a980f895b045b1fe1e5 (resized).png4cab5e20bb664ce367dc7a980f895b045b1fe1e5 (resized).png
#6759 5 years ago
Hope this helps
No not the mummy, the rising ramp on LE, it is the VUK switch underneath in that scoop that got broken and now won't register a ball in there, switch appears fine and works in test but can't a ball to register it. Pretty much makes game unplayable and I'm so frustrated.
#6760 5 years ago
Not at home right now hope someone helps ) if not i will help you tomorow
#6761 5 years ago
#103 has been pretty much a nightmare since opening breaking my streak of minor to no issues with nib Stern games. I sort of knew what problems I would have out of the box. Did not expect to have my ramp frozen in the up position since this raising ramp has been in a bunch of other games over the years. But like the sarcophagus the ramp mech could be an issue for some.
I love the game (only have 3 games on it)and will fix my issues but in a week when premiums start showing up, people are going to freak over the same issues I am having. Quite obvious from talking to Stern tech that they really did not perfect either of these two upgrade features and are dealing with a ton of issues from owners like me.
Worst part is I see nothing wrong visually with either mech. Going to take apart the ramp over this weekend and hopefully find something wrong. My guess it's a coil issue (I hope).
#6762 5 years ago
Quoted from starbase:
Does the ramp go back down after powering off the game and restarting a new game? Or is it always up?
#6763 5 years ago
Quoted from pinstadium:
A little of both, seems to drop down at random times but mainly it stands up tall and does a little shimmy when the coil fires. So it does go down but not from powering down the machine.
#6764 5 years ago
Does it try to go down when it’s supposed to? Doing that shimmy? Maybe if you can post a video up of it that might help.
#6765 5 years ago
Will the moving ramp on Maiden possibly scratch up the PF?
I recall TWD Premium/LE players & owners reporting issues of a clunky ramp feel and scratched PF’s
#6766 5 years ago
Quoted from PW79:
Just put a piece of mylar there if it doesnt already have one and you should be good to go.
#6767 5 years ago
Quoted from Who-Dey:
It does have Mylar under the ramp. I’m sure Cliff will have a Cliffy for it soon, just like he did for TWD.
#6768 5 years ago
Don’t take apart the ramp. I had the same issue. If yours is the same, the back part of your ramp has a sharp lower edge and is rubbing and catching on the ball guide behind and below it. It’s sharp metal on metal and causes it to stick just long enough that the release coil has finished its attempt to let the ramp down. My fix was to put a tiny bit of 3in1 oil on a qtip and run a little oil on the ball guide. Problem solved. In my opinion, these should not be touching, so I’ll be looking at adjusting the coil and/or coil stop so the ramp does not raise so high, thus not rubbing the ball guide.
#6769 5 years ago
I don't own the game yet but plan on getting a premium. I'm almost 100% sure that switch needs two screws to work properly. With only one screw, you would have to tighten it severely to hold the switch in place. If you over tighten screws on switches like this, the switch may not work at all. Just get another screw, either from Stern, PBL, Marco, etc. Then adjust the switch slightly until it registers with a ball.
https://www.pinballlife.com/index.php?p=product&id=1381
#6770 5 years ago
Quoted from Tranquilize:
I did that same thing and the ramp started getting stuck again after about 10-15 games or so.
Just installed the new ramp assembly that Stern sent me and its perfect again for now.
33
#6771 5 years ago
Got my premium last week. Set it up next to my pro.
0C02EADB-B84E-4ABD-94D6-DD47E70E6EE1 (resized).jpeg0C02EADB-B84E-4ABD-94D6-DD47E70E6EE1 (resized).jpeg
7A4BAF4C-7C7E-4E14-83C8-2FB11A9011A6 (resized).jpeg7A4BAF4C-7C7E-4E14-83C8-2FB11A9011A6 (resized).jpeg
48F1CD5B-31D2-411A-94FD-7290F1F23C1A (resized).jpeg48F1CD5B-31D2-411A-94FD-7290F1F23C1A (resized).jpeg
AAE2C6C8-A486-4EDC-A2A8-1C4858E252E6 (resized).jpegAAE2C6C8-A486-4EDC-A2A8-1C4858E252E6 (resized).jpeg
F464C9F4-2044-4B2F-A820-C72ACB857B83 (resized).jpegF464C9F4-2044-4B2F-A820-C72ACB857B83 (resized).jpeg
6D098630-E2F6-419A-9F02-214082D3103F (resized).jpeg6D098630-E2F6-419A-9F02-214082D3103F (resized).jpeg
B98D02ED-31C2-4D44-AA18-AF3D0A2410EB (resized).jpegB98D02ED-31C2-4D44-AA18-AF3D0A2410EB (resized).jpeg
48DB6993-62B8-48F1-A4C1-926BBA9A83BE (resized).jpeg48DB6993-62B8-48F1-A4C1-926BBA9A83BE (resized).jpeg
365E2CAE-CDAC-4A50-8F3C-0973719BA0D9 (resized).jpeg365E2CAE-CDAC-4A50-8F3C-0973719BA0D9 (resized).jpeg
106C111E-184F-4FA4-AC08-F8779C30F7BD (resized).jpeg106C111E-184F-4FA4-AC08-F8779C30F7BD (resized).jpeg
C55B3F4A-C968-406B-966A-77085E1D97A3 (resized).jpegC55B3F4A-C968-406B-966A-77085E1D97A3 (resized).jpeg
BB811B4A-9EEF-4979-9841-00352030C00B (resized).jpegBB811B4A-9EEF-4979-9841-00352030C00B (resized).jpeg
39A9B99C-B6A3-4898-A54D-11DC59819605 (resized).jpeg39A9B99C-B6A3-4898-A54D-11DC59819605 (resized).jpeg
3F5F2818-932D-4B92-86F9-8B6E5E64A025 (resized).jpeg3F5F2818-932D-4B92-86F9-8B6E5E64A025 (resized).jpeg
#6772 5 years ago
Nice lineup Tatman, premium looks great.
#6773 5 years ago
JEALOUS! I hope to hear from my distributor this week. What code was it running when you got it?
#6774 5 years ago
Quoted from SpecialK-33:
.97
#6775 5 years ago
Quoted from Chalkey:
Mine was really early and shipped with .91 code.
Re:auto plunger- figure out if its hitting off the bottom of the upper right flipper pr exiting the shooter lane at too low of a trajectory. This is most easily accomplished by going to the menu, diags, coil test and testing the kick out coil. It'll spit a ball out and launch it. Get up close with the glass off and make sure it's not hitting the upper right flipper and determine if it's hitting high or low of the target loop. Remove the right middle plastic to reveal the adjustment screw for the top rail of the shooter lane. Adjust and retest.
Mine was giving me a fit as I thought it was set too low and it turned out it was just *barely* grazing the upper right flipper about 1/10 times.
If your manual plunger is not dead center both left right and up down it will also cause missed and rattling through the loop making the super skill shot very hard to obtain.
So after doing what Chalkey said, my auto plunger and manual are back to working like a Swiss watch. I had to move the top rail of the shooter lane up. This was after messing with the auto plunger strength, leveling the game different ways, etc. There is some room to move the top rail under the screw, see pic. Thanks for your input!
36F4EB9E-CCC6-484B-A9B1-92CC776BFA4D (resized).jpeg36F4EB9E-CCC6-484B-A9B1-92CC776BFA4D (resized).jpeg
#6776 5 years ago
Quoted from kpg:
Mine has been fine for about 30 games so far. What was different about your new assembly?
#6777 5 years ago
That premium looks nice out in the wild.
#6778 5 years ago
Has anyone seen the 50 les that the band reserved? Not on the bands Web store.
#6779 5 years ago
Quoted from tatman9999:
Can we be friends... I mean... Man, what a great collection... And you must be loaded if you can basically buy the same pin twice... a bit Jelly as I prefer the pro art package, but I really wanted to have the gameplay of the prem. As I think the lock ball device is a really cool idea, and who doesn't love ramps that go up and down.
But, man... You got a collection like how I hope to have one day. To have so many options at playing pinball in one house... That's living the dream.
#6780 5 years ago
Not much, other than the coil arm of the new one doesn't seem to extend as far and get caught up like the defective one.
Here's a pic of the entire assembly which took me 5 mins to swap out. Super easy
#6781 5 years ago
My armor im gonna put on my premium coming. Contact me if your interested. I call it pharrohs gold
#6782 5 years ago
Quoted from Robertstone0407:
Post some pics with the Armor on game ASAP!
#6783 5 years ago
Just a question when I see some videos: isn’t it too tough to keep an eye on the lower flippers, on the upper right flipper and the more upper left flipper on multiball?
#6784 5 years ago
Quoted from colonel_caverne:
Yes ... its difficult to keep track of everything and my mb dont last real long. And man the left outlane is brutal on mine
#6785 5 years ago
Quoted from bigd1979:
As long as this is not frustrating, i guess it is OK...
#6786 5 years ago
Nice collection
Curious to read your opinion on gameplay pro versus premium. Having both make you like an expert
#6787 5 years ago
Once you get used to the gameplay, you can move your focus around. I find that I can still know where the lower balls are for short bursts of attention up top. There’s nothing cooler than hammering 3+ Big loops during multiball without losing a ball! Nailing the large and small loop at the same time is epic, epic, epic!
#6788 5 years ago
Quoted from Rensh:
Nice collection
I've played both and to be honest there isn't much in it; although I always go LE or Premium for the full show (lights etc).
Neil.
#6789 5 years ago
Sounds like you're flipping the big loop too late
#6790 5 years ago
Of course it's frustrating! That's the point. Who wants to play a game where every shot is easily made and returns to the flipper with no risk?
Play better!
#6791 5 years ago
Quoted from Fytr:
Play better!
Ha ha ha
So have a nice frustration!
#6792 5 years ago
I dont find Iron Maiden to be frustrating at all. In fact, the games and ball times can be longer than other Sterns IMO, especially my other ones MET/TWD/and especially Star Wars which I find to be even faster and more challenging than Maiden and definitely more frustrating (in a good way!)
Overall, Maiden is an excellent pin and its frantic and crazy but not at all frustrating. IMO, the most frustrating shot can be the left ramp trying to make it through the poppers and combo-ing the ramps in Mummy Multiball.. I just can't seem to combo them much... practice makes perfect though!
#6793 5 years ago
Quoted from kpg:
KPG, I agree with every part of your post...
#6794 5 years ago
Quoted from NeilMcRae:
Neil.
I find them to be quite different yet in subtle ways. The LE/premium add a little more stop and go to an insanely fast game. This allows for a better mental balance in my opinion. I also find some of the modes to be better with the underworld, and the left orb is a great addition. Lastly, instant mummy multiball is so much better! I've found my LE to be more enjoyable than the pro. The pro is still a great game though and kills it on bang for buck.
#6795 5 years ago
My max combos on the ramps is 7...most of the time it’s maybe 2.
#6796 5 years ago
yes agreed but I don't think its widely different, not missing out on anything major was my main point.
#6797 5 years ago
Quoted from MikeS:
The problem with most LE/Premium features in games is that Stern underutilizes them in code. They don't typically want to make the game experience that much different from the Pro. Things like the Iron Hyde playfield in transformers, the GOT upper playfield, ACDC lower playfield, X-Men pop-ups, etc. just don't get utilized to their full potential and don't have very good rules built around them. Maybe that will change on Maiden but as of now I don't think the extra premium features give you that much extra as far as gameplay enhancements go.
sorry a little late
I agree with this 100 percent / perhaps that is why the games are cheaper too / extra stuff that does not do much as opposed to an extra Mode or something like Daft punk in Tron .
#6798 5 years ago
Quoted from PinFever:
sorry a little late
There is an extra mode in the PRE/LE that is not in the Pro. Keith announced it on a podcast this week. It's based around Can I Play with Madness and has the ramp going up and down and you have to time your shot to get it under the ramp.
-5
#6799 5 years ago
Quoted from trilamb:
That mode will be programmed in the pro too but just not in there yet it is on the backstage pass too for the pro
12
#6800 5 years ago
Quoted from musketd:
That's not what Keith said on the podcast.
6,700 (OBO)
Wake Forest, NC
$ 5.00
Pinball Fuzz
$ 24.50
$ 50.00
arcade-cabinets.com
Twisted Tokens
Lighting - Backbox
Myth Pinball Parts Shop
arcade-cabinets.com
$ 27.95
SilverBall Designs
$ 100.00
Duke Pinball
YouBentMyWookie
$ 55.00
arcade-cabinets.com
Pinball Pro
$ 18.95
7,000
New Cumberland, PA
$ 55.00
Tucson Pinball
$ 8.99
Inscribed Solutions
$ 9,499.00
Quality Billiards
$ 24.00
Pin Monk
Filament Printing
$ 7.95
SilverBall Designs
arcade-cabinets.com
8,200 (OBO)
Fort Lauderdale, FL
$ 34.00
Pin Monk
This page was printed from https://pinside.com/pinball/forum/topic/next-new-title-from-stern-announced-this-saturday/page/136 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
