We started in 2012 with our first generation Playfield Protectors, which maybe some of you already know from ebay or other online shops.
In the meantime we developed playfield protectors for more than 200 pinball machines, plastic protectors for more than 100 pinball machines, clear plastic sets for more than 60 pinball machines and a lot of other useful stuff.
Now it is time to move one step forward. We set up our own online shop introducing the Next Generation Playfield Protectors.
The Next Generation Playfield Protector is now made of Vivak (PET-G) instead of macrolon, which allows us to reduce thickness (50 % reduction of thickness – now only 0.5mm / 0.02‘‘) and improve the edges by using CNC lasers instead of CNC molding cutters. The new surface is now even more transparent with still being glossy. We ship flat packaged to avoid "rolling effects".
Our playfield protectors are precut protectors, which fit individually to each pinball machine type.
Depending on the particular pinball machine, a protector can be installed within a few hours including cleaning, which should be done in parallel. The playfield needs to be partially stripped down, so that the protector can be easily placed on the playfield.
Please check out our new online shop to learn more about our products and subscribe to our newsletter to get a 10% discount code for your next order.
