(Topic ID: 247792)
Next Stern title is JP2 Jurassic Park
By Whysnow
2 years ago
  • 3,615 posts
  • 534 Pinsiders participating
  • Latest reply 2 years ago by TheLaw
  • Topic is favorited by 61 Pinsiders
Jurassic-Park-LE-Flyer.pdf (PDF preview)
There are 3,615 posts in this topic. You are on page 59 of 73.
#2901 2 years ago
Quoted from lapean111:
Garbage design all around, from a designer who no one should be supporting any more.
Playing and/or owning GB is not "supporting" him the way you framed it here.
Quoted from sethi_i:
As for the other statement, I supported my local distributor. I don't know who you gave your money to.
Yes, this.
#2902 2 years ago
Anyone worried about the T-rex malfunctioning too often on Prem?? Deal breaker? I'm hopeful Stern can get it worked out by Sept for Prem production.
#2903 2 years ago
Quoted from Morhaus:
Yep....noticed that it malfunctioned during the video stream....also a little worried about play field damage along with the ball getting stuck. Probably ok in a home environment if it doesn't happen often, but could be a nightmare on location.
#2904 2 years ago
Well the Death Star famously malfunctioned in the release video as well so maybe it's juts a shtick they're doing?
#2905 2 years ago
It malfunctioned once, on a prototype machine. Not too worried. A Premium (same pin?) will be at Pinburgh, so if it is a problem should find out more then.
#2906 2 years ago
Quoted from Sinestro:
Looks like a few of no-brainer mods could be made for this game. Better looking control tower for all models. For the Pro, helicopter blades that spin with the ball hits, Raptor replacement, perhaps some kind of T-Rex mod.
I'd like raptors that pop out of the playfield under the map, but that SLE doesn't exist!
#2907 2 years ago
Quoted from dts:
I would like a dino that eats the ball, raptors that pop up underneath the playfield, and sone cool display animations of the T-rex eating the lawyer off the toilet.
#2908 2 years ago
Quoted from Daditude:
Now you’re talking! If nothing else, the lawyer on a toilet and spring that Trex hits occasionally!
#2909 2 years ago
Yes, very sure. Have owned GB and played tons of BM66. BM66 flows for days compared to GB. The right ramp on the premium didn't even work as designed. Needed to be lowered to get the ball to even be able to make the turn. Garbage design all around, from a designer who no one should be supporting any more.
Theres more to pinball then two standard ramps that return the ball directly to the flippers.
#2910 2 years ago
Quoted from PanzerFreak:
Why is the tower literally several pieces of thin plastic with bare metal screw heads all over?
Cost savings. And it gives the mod-makers something to improve on.
#2911 2 years ago
Finally got to the end of this thread
Watched parts of the stream between jobs on night shift this week and unless I missed it there wasn’t a lot of fan fare/choreography with the t-rex or it was easily missed if it was there.
I was kinda hoping for a big visual display, dropping out the GI and popping flashers and lights off that backboard to replicate the t-Rex coming through the fence in the rain and lighting, just something to make it really stand out.
#2912 2 years ago
Quoted from PtownPin:
Yea I’m not too worried about ball hitting the PF happens a lot anyway in most pins heck SM web sling drops the ball a lot more often than T-Rex but who knows maybe Stern is using cheaper wood these days. Hopefully they put some Mylar in pop area from factory. Have done in past like in ST it’s unnoticeable and probably helps somewhat.
#2913 2 years ago
If you're worried about the ball hitting the playfield just set the T-Rex to always drop it on the ramp, it's in the settings.
#2914 2 years ago
Quoted from Aurich:
Good intel...how do you know that? Did they mention it on the video stream?
#2915 2 years ago
Yes, they mentioned that it was a setting in the stream.
#2916 2 years ago
It could be set to throw the ball randomly, or to only drop the ball into the left wireform.
#2917 2 years ago
Post #2157 of this very thread.
#2918 2 years ago
Anyone know where this instruction card was from besides the leaked photos? Looks like it has a part number on it but isn’t on the LE.
#2919 2 years ago
Quoted from Aurich:
If you're worried about the ball hitting the playfield just find a new hobby. set the T-Rex to always drop it on the ramp, it's in the settings.
Fixed your post. Making a joke here, but man I can't imagine liking this hobby and worrying about something happening that's literally happening hundreds of times per game.
#2920 2 years ago
Quoted from J85M:
I was thinking the same thing when I watched it. Like all the lights should go out except for a spotlight on him. Maybe in future code?
#2921 2 years ago
Quoted from tpir:
Yeah, I'm assuming he's also never leaving prison for the rest of his life.
Quoted from J-Freeze:
And if you plan on leaving it off, )though you can also select it to drop onto the wireform) maybe just go for the Pro.
From what Keith said the three settings are off position, wang dongling random drop position, and direct wireform drop position.
He didn't use those words exactly, mind you.
#2922 2 years ago
Quoted from SheriffBarclay:
really...I own a lot of games and not one of them shoots the ball in the air and lands on the play field...every now and then you'll get an air ball, but as u stated thats pinball....with these softer play fields it might be a concern? who knows? the good news is you can make the change in the software setting....sounds like u need to make a few adjustments your games
#2923 2 years ago
Quoted from wesman:
I think the 3 settings are just for the "thrash and throw" feature.
1. Random
2. Into the pops every time
3. Off
With it "off" the default is to just drop it on the wireform. As in dropping on the wireform is not considered "thrash and throw".
Turning the "drop on wireform" off is probably a separate setting to just disable the trex interaction all together.
#2924 2 years ago
I'd like to think with enough concentrated Trex ball drops, he'll be simulating the meteor onto your playfield that killed his kind.
Sweet, sweet REVEEEEEENNNGE!
#2925 2 years ago
Plenty of games where balls fall from height onto the Playfield.
#2926 2 years ago
1. Random
3. Off
Wonder what the default is. Definitely ads an element of randomness. Competition players will hate it.
#2927 2 years ago
Quoted from cooked71:
Doesn’t the ball fall off clown head on CV?
#2928 2 years ago
Don’t know the ball lands up in the upper PF it not being thrown STM.
#2929 2 years ago
I will assume that those who are worried about a random toss from the dinosaur has never owned or played a Cirqus Voltaire. Many other examples I'm certain.
And I don't want to set off a wave of panic but the ball drops at the end of the return ramps (on any game) should be far more of a concern than this.
(edit) Jinx @ Rai
#2930 2 years ago
I believe u....none of mine do All I'm saying is with the soft play fields there could possibly be an issue in the future. Who knows maybe mylar helps? Only time will tell.
#2931 2 years ago
Quoted from rai:
yep, Spiderman it gets slammed into the PF, Twilight Zone, Aerosmith, Dialed in, heaps of games.
#2932 2 years ago
Quoted from rai:
True, dont know where it can land - if its only the pops thats not going to make any difference.
#2933 2 years ago
This is what has been said on Pinside from what I have read:
Quoted from sk8ball:
There are 3 T-rex Thrash- throw settings. Random, pops, never. If you are worried about breaking wireforms then set it to off
#2934 2 years ago
So I didn't watch the entire stream was too chaotic with all those people playing and the dinosaurs costume. Can someone explain the map how it works and how you can tell when a carnivore is approaching etc?
#2935 2 years ago
Quoted from rai:
Just keep your eyes on the right of the screen. You don't have to look at the people.
#2936 2 years ago
Quoted from Mr68:
(edit) Jinx @ Rai
I think on avg Bally/Williams playfields were better than todays standards.
#2937 2 years ago
3 mini wizard modes according to the apron card!
RAPTORS IN THE KITCHEN, MUSEUM MAYHEM, SECURE CONTROL ROOM.
Tell me more! It sounds great!
#2938 2 years ago
Do you have to play each paddock you navigate to, or can you continue traveling to a harder distant paddock first?
#2939 2 years ago
Here’s my takeaway on rules as far as I can tell
Main modes:
- hit 3 white shots to spell MAP
- then hit trex ramp which moves your virtual car to the next of two spots (AKA paddocks) on the map. The specific paddock is determined by which way the car is facing when you hit the trex ramp
- next, depending on the specific spot you are on you get to capture a specific dinosaur to add a unique perk, which is represented by a roving green shot. This is accomplished first by hitting ‘set trap’ targets, then the helicopter shot, and then the now flashing green shot. While you are trying to do all this, the green dinosaur shot moves towards the orange shots that represent humans to rescue before the dino gets there. Rescue enough and get an extra ball.
- keep moving to end of map to get one of the mini wizard modes
Side mission: trex modes
- hit truck 4x to spell trex, then hit trex ramp to start these modes that have the trex head move on the premium and le
Side mission: control room
- shoot far left scoop to start these modes when lit. Not sure how they get lit though.
- play these modes to get another mini wizard mode
Pteranodon:
- shoot the back right ramp a bunch of times, then a switch hit frenzy starts. Get a bunch of switches and then hit the back right ramp again.
I’m guessing the last mini wizard mode has you collect all the fossils but I’m not sure how to do that.
Digging the rules so far.
#2940 2 years ago
What’s the action button going to do?
#2941 2 years ago
Quoted from pickleric:
I hope collects dino turd bonuses....
One can dream, anyway.
16
#2942 2 years ago
Photos of the optional side armor :
JP-Side-Armor-2-e1564158717469 (1) (resized).jpgJP-Side-Armor-e1564158691575 (1) (resized).jpg
#2943 2 years ago
As touched on by previous posts, making an injection mold is costly, and 3D printing is too slow and lacks detail if you use the cheaper machines. Another option is to resin cast from a 3d printed or hand sculpted master. I am not so sure Groot in GOTG isn't a resin casting of some sort. Resin casting is relatively cheap from a materials cost standpoint...but you will have some time in mixing, pouring, curing, demolding and then repeating the process a few hundred times. And also don't forget....you are going to have to paint these parts somehow as well. You need to pay an employee or employees to do that. So yes, there is quite a bit that goes into a 3d molded sculpt compared to some screwed on pieces of plastic.
14
#2944 2 years ago
Just watched another 30 minutes of the stream.
There’s so many satisfying shots in this game:
- the right mini ramp shot.
- the raptor cage
- the left tower shot
- left upper loop
- center loop shot
Not to mention the 2 main ramp shots which are fantastic. Game just looks incredibly fun to shoot.
Any complaining at this stage really is just nit-picking.
I get that it’s not perfect - it’s a shame there’s no actual footage, that the callouts could be better, that the art isn’t art gallery worthy, that there’s some plastics that could have been sculpts.
But one of the best things is the game doesn’t take itself too seriously. It just looks like fun and for some reason I feel like that’s been missing in pinball since the 90’s.
#2945 2 years ago
R u serious? theres a ton of fun and dare I say much much better pins in recent times than anything from the 90's. I love the 90's stuff as well but I don't think the pins in the last 2 decades lack fun factor.
#2946 2 years ago
Quoted from Hazoff:
Yeh, that’s a bit of hyperbole. But it’s few and far between. So many games take themselves too seriously. The 90’s games, whilst I personally think they’re not as good as many games today, were just fun games.
I’m by no means saying there’s been no good games since then. Just talking about a lack of fun.
And lack of good, new, satisfying shots. There’s been so much cookie cutter lately. This is just a bit of fresh air. Which reminds me of the 90’s when they took risks with shots and layouts.
#2947 2 years ago
Quoted from Hazoff:
R u serious? theres a ton of fun and dare I say much much better pins in the recent times than anything from the 90's. I love the 90's stuff as well but I don't think the pins in the last 2 decades lack fun factor.
I can count the # of UNFUN games released in the last two decades on one hand and without removing my mittens first. Let’s see - Avengers, Jetsons, Thunderbirds.
#2948 2 years ago
What are the rules about the raptor pen area?
What happens if you lock s ball there and then drain? The ball stays there for the next player? I guess a hit to a captive ball would count as a lock then.
#2949 2 years ago
Quoted from jeffspinballpalace:
I can count the # of UNFUN games released in the last two decades on one hand and without removing my glove.
Sure, all pinball is fun to a certain extent.
#2950 2 years ago
.. and fun enough to spend 4 quarters on to play a few times. Most games aren’t fun enough to buy, but that would be impractical.
