Hi. Anyone seen the issue where engage left flipper up when ball come back and hits the flipper it flutters all while the cab switch is engaged also. I swapped coils and cab switches and it still does it. This is on a batman dark night. Any thoughts
Check the mosfets, I had a Bdk which had the wrong type of mosfet and this caused such strange behavior.
If the flipper was in the up position and a fast ball knocked against it, it just fell down.
If I’m not mistaken the correct type was a 40nf10L and the 40nf10 doesn’t work...
Bingovit. Nice lead will check
Thanks and thanks DNO
Quoted from Bingovit:
That’s what the EOS switch is there for in modern games - to ensure the flipper holds strongly when hit by a fast moving ball.
That’s almost certainly the issue. Either the switch is misadjusted, broken, or the actuator has broken off (which is somewhat common).
