Hi all, I am a complete newbie and have very little idea on electronics but I have an issue.
My Adam’s family has started blowing the 5amp slow blow fuse in the main power supply box.
I unplugged all connections to the power supply and put another fuse in, hoping I could slowly plug each run back in including the main coil but the fuse blew again.
Firstly should the power supply be able to be powered up and not blow the fuse with nothing connected?
And I guess in relation to this, probably obvious to some but with the fuse blowing when only this has power does that mean it is faulty.
Lastly any help as to whether to replace the whole power supply (should this be the issue) or just components in it?
