Hello,
I'm experiencing a problem with the outhole kicker switch on my Whirlwind. In the 1st video (see link below) you can see when the ball drains and enters the outhole trough, it does not trigger the kicker solenoid to kick it back into the ball trough. I ran a "switch edges" test and confirmed when I manually press down the switch the machine doesn't register a signal.
Furthermore, when I ran a coil test, the outhole kicker solenoid seems to work fine as the machine cycles through all the other solenoids. However, when I stop the test on the outhole solenoid to test it repeatedly by itself, it seems to get stuck after the coil fires a few times (see 2nd video linked below ). Not sure if this is related to the switch problem, or maybe a separate issue. I did notice the brown arm connecting to the solenoid seems to look loose and not straight. Should I tighten the nuts above it, or is it supposed to be this way?
Can anyone clue me in on how to fix these issues? This is my first machine, and I'm motivated to learn how to maintain and repair it. Any help is greatly appreciated!
