Welcome to Pinside! WCS is a great game.
If I remember my brother's WCS correctly.....Switch 41 on the goal trough is an opto ("electric eye") that detects when the ball rolls past it on the way to the VUK (vertical up-kicker) on the RH side of the goal. An opto has a transmitting side (LED) and a receiving side ("eye").
Easy way to check is to go into "Test" mode in the menu, select "Single Switch", and then use your finger or a piece of paper to break the beam of the opto. It should beep at you and show Switch 41 on the display. If it doesn't, you may have a bad opto.
To check this, first look at the transmitter side. The LED should be lit up (most likely red). To check the receiving side, look at the opto with the camera on your phone, as the naked eye cannot see the light wavelength emitted. A functioning opto should look lit up in a purple hue.
If either opto side is burned out, you'll have a little bit of soldering to do....
Good luck!
Later,
EV
