(Topic ID: 220846)
Newbie EM questions
By MrFancy
5 years ago
  • 7 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by MrFancy
    #1 5 years ago
    I’m new to the hobby and considering buying a 1960’s EM in good condition (meaning works 100% and has a lot of new parts on the playfield). I don’t know anything about maintenance and repairs but I definitely want to learn the basics. I expect to play it regularly but not heavily, say 20-30 plays/week.
    What I want to get a sense of is, what am I getting into? Assuming I can fix minor issues, how often can I expect to have bigger problems that a beginner like me won’t be able to fix on their own? I know it’s impossible to say for sure, but for a typical 1960s EM would you say most likely a couple of times a year? More? Less?
    Thanks for any input.
    #2 5 years ago
    For an EM, there's pretty much only two classes of issues. 95% will be the same simple easy thing, the other 5% will be crazy weird cases that you hope you don't run into. Most of my EMs have been running for years without issues, and those 5% ones don't usually crop up during normal use
    #3 5 years ago
    Start here:
    http://www.pinrepair.com/em/index.htm
    You'll want to print it all out so have plenty of paper & ink in your printer.
    #5 5 years ago
    If it really works as intended and you only play a dozen or two games a week, you should only need to worry about routine maintenance like waxing and replacing light bulbs. More than likely though, it's not exactly 100% and you'll need to clean some various things and adjust the gaps on some switches. It's all straight forward and Clay's guide will teach you just about everything you need to know. I'd recommend buying a box of replacement incandescent lightbulbs, some microfiber cloth, caranabu wax, some Q-tips, some 91% (or higher) rubbing alcohol, and a switch adjuster tool. That's a pretty good beginner toolbox for an EM. Also consider buying some new rubbers and a new ball if they haven't been replaced recently.
    #6 5 years ago
    The more you play an EM the better off you'll be as far as dirty switches. Let an EM sit for 6 months without playing and you're guaranteed it won't work right when you do.
    #7 5 years ago
    All of this is super helpful to me and I appreciate it, any other advice also most welcome!
    This page was printed from https://pinside.com/pinball/forum/topic/newbie-em-questions- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
