Here's the new Read Me!!!!
V1.41 - Aug. 25, 2015
- Added a setting that will light the crossbow at the beginning of the
game.
- Fixed lamp effects for tilt warning, tilt, and slam tilt that handle
the RGB LEDs and the LED GI properly.
- Darkened G.I. for the game over lamp effect.
- Added LED G.I. effects for:
- Skill shot.
- Woodbury skill shot.
- Pop bumpers (RRX).
- Outlanes (BIT).
- Walker kills.
- Multi-kills.
- Prison
- Hit, letter, yard walkers, multiball.
- Well walker
- Hit, letter, rescue, multiball.
- Bonus.
- Blood bath multiball lit/ready and modes lit/ready.
- Match.
- Modes: BARN, CDC, RIOT, TUNNEL, and ARENA.
- Extra Ball Lit, Extra Ball
- etc.
- Added a lockout for the zombie bombs at ball start / ball serve.
- Fixed a bug that was preventing the fire button from being updated
correctly.
- Added a setting to the woodbury skill shot that allows the skill shot
positions to be locked out after a woodbury skill shot award is collected.
This prevents the player from being able to continually collect woodbury
skill shot awards from the same position.
- Collect bonus from woodbury skill shot now shows the bonus that is
collected.
- Added lamp effects, sound effects, and increased scoring for Siege.
Added score display for final shot.
- Added switch compensation for the prison.
- Increased the volume of the prison doors open/closed sounds.
- Added sounds for multi-kill weapon wipe.
- Added display effects for HORDE and LAST MAN STANDING "keep shooting".
- Added a rule for killing all of the walkers (Last Man Standing).
- Added a rule for playing all of the modes (Escape Terminus).
- Fixed bugs in CDC and TUNNEL mode that set precondition data for BARN
mode instead of CDC/TUNNEL modes. This resulted in multi-kill starts
for BARN (as long as it had not already been played) and an additional
multi-kill start for completing CDC/TUNNEL. This has been corrected.
- Added settings that allow the user to control the behavior of the
multi-kill modes better:
- Starting a multi-kill from PRISON MULTIBALL or WELL MULTIBALL can
be set to "collect super jackpot". This is the default for
COMPETITION mode.
- Starting a multi-kill from the CROSSBOW can be turned off, or
be set to "kill all walkers". Multi-kills from the CROSSBOW are
turned OFF for COMPETITION mode.
- Starting a multi-kill from the ARENA mode can be set to "complete
mode". This is the default for COMPETITION mode.
- Starting a multi-kill from BLOOD BATH MULTIBALL can be set to
"collecting all supplies (jackpot)". This is the default for
COMPETITION mode.
- Starting a multi-kill from the TUNNEL mode can be set to
"complete mode". This is the default for COMPETITION mode.
- RIOT mode default number of shots for multi-kill changed from 2
to 3.
- Starting a multi-kill from the CDC mode can be set to "complete
- BARN mode for COMPETITION requires 5 shots instead of 3 for
multi-kill start.
- Starting a multi-kill from collecting all of the heads in the FISH
TANK can be turned off. This is the default for COMPETITION mode.
- Starting a multi-kill from the BICYCLE GIRL can be turned OFF, or
started when the mode is completed. The number of hits to the
BICYCLE GIRL for completion has been lowered from 4 to 3, and the
default number of hits for starting a multi-kill has been lowered
from 4 to 3. The bicycle girl mode must be completed for COMPETITION
mode.
- Starting a multi-kill from the SUPPLIES can be turned off. This is
- Starting a multi-kill from the COMBOS can be turned off. This is
- Lowered the switch score for the RIOT mode.
- Increased the final jackpot value for the ARENA mode.
- Fish tank lamp (on the right ramp) now updated properly.
- Reorganized calls to award functions for the shooter lane shot. The new
sequence is: MODES, SIEGE, SPINNER JACKPOT, and EXTRA BALL. The EXTRA
BALL display effect was not being queued. This meant that if there was
a higher priority effect running (prison, mode, replay, etc.), the EXTRA
BALL display effect would not run. This has been corrected.
- The sound effects for extra ball would sometimes not be made due to
higher priority sounds interfering. This has been corrected.
- Added HORDE fail art with sounds.
- Fixed a problem with mode scoring. When the last mode was started,
"modes completed" was being bumped, which caused the last mode scores
to be higher than normal, since modes are worth more the next time
played. This has been corrected.
- Fixed problems with the return lane sounds. When the X shot multiplier
was lit (or running), the normal return lane sounds would not come
through.
- Added a lamp effect for activating the "X" return lane.
- Skill shot maximum increased to 5M.
- Added a lamp effect for extra ball.
- Added a lamp effect and sound effects for extra ball lit.
- TUNNEL multi-kill was specifying the preferred starting shot to be the
left loop shot instead of the right loop shot. This has been corrected.
- Shot multiplier, along with X champion HSTD sequence, has been extended
(instead of terminated) when the left prison standup target is hit. The
only follow-up shots allowed at the moment are the center lane and the
center lane standup. This allows the player to clip the left prison
standup target and still get credit for COMBO/MODE/PRISON.M.B./etc.
awards on the center lane at the multiplied value.
- Added speech for lighting woodbury; fixed speech spacing with fish
tank and woodbury lit.
- Removed woodbury lit/start effects. These were getting in the way of
everything.
- Limited the follow-up speech that is requested for blood bath multiball
jackpot and super jackpot.
- Fixed issues with resetting the multikill data for the preconditions
when HORDE is started (CROSSBOW and FISH TANK were incorrect).
- Reworked the multi-kills such that the modes that start them will
continue to add points as long as the multi-kill mode is still active
(effectively, until the end of the ball).
- BARN mode start instructions were not being rendered using the outline
font. This has been corrected.
- Increased the scores for the bicycle girl mode.
- Added topper effects for game start and player added.
- Fixed up skill shot background so it shows billion scores correctly.
- Added extra sounds to the attract mode. When a walker growl sound is
made, there is a light show and a topper effect that will run with it.
- Added a setting to keep modes from being lit/started during multiball.
The default has been set to YES (this is the same behavior as all
versions prior). The setting for COMPETITION mode only allows lit modes
to be started during multiball.
- Shortened the lighting effects for the skill shot.
- Tightened up the well walker start display effect.
- The bicycle girl feature was allowed to start during HORDE. This has
been corrected.
- Added a lamp effect for well multiball victory lap jackpot.
- Display effect sequence was not clearing pending effects when a TILT
occurred. This has been corrected.
- Fixed up some background lamp effects. Some background lamp effects
(modes, specifically) were running at end of ball when they should have
been killed off.
- Fixed more bugs/problems with previous mode shot scores.
- Crossbow scores carryover was set to YES instead of NO. This has been
corrected.
Well, I know what I'll be doing this weekend! Not sure how it will macro from the old to the new, but I promise we will all be having an epic Labor Day Weekend
EDIT: Post #153 on page 4 will get you to the downloads
Look at all those GI lighting effects they've added! Nice.
Quoted from cleland:
Quoted from T7:
This was needed on the Premium/LE given what a dangerous/risky shot this is.
What does this mean:
New modes?
Not sure what they mean by "added a rule".
Quoted from PinJeff:
New modes?
Modes that I saw in the code but were not implemented into the game yet.
I think this might mean all modes are implemented and it's complete? Maybe just some tweaks or bug squashes, but it might be done?
Can't wait to see all the lighting stuff, especially with my new topper
They had said a while ago 2 more updates, and this would be the second one. So we might be done, except for bugs.
Umm, so I just played my first game on 1.41 on my LE.
Wow! Way better gi lighting! I think this could be amazing...
thanks Lyman and Stern. Cant wait to try it out and see if a macro can load the custom sounds without issue.
Quoted from ezeltmann:
I just did a quick look here at work and it looks like running a macro won't cut it.
I might have to do it sound by sound again....at least the sound requests were close to the existing one, but different values when I compared the two.
Let me know what you think.
I think I really appreciate your work, no matter what you decide.
Quoted from frolic:
Is last man standing done?
Quoted from LTG:
Thanks Lloyd!
I've been through the sounds so many times I don't mind doing it line by line again. It will let me add some new ones in too.
Quoted from MarcG:
Yes, I believe all modes are done. Escape Terminus was one I never even knew about. Cool!
This may mean 2 new modes are added to this release
It's worded a little non-descriptive, but it may be...
Wow. What an update! Amazing color changes. This was my first premium and I was a little down because of the non changing lights but man am I glad I got it now!
Quoted from T7:
I believe this means that last man standing is now activated if you kill all the zombies and terminus is activated if you complete all the dead features (barn, cdc, riot, tunnel, and area)
Yeah, the biggest reason I bought the LE was for a better light show. Now it goes nuts. Love that the zombie kills dim, love that the bites flash the game, everything is so much more atmospheric.
Played two games and got to Blood Bath and Horde. The light show all around is greatly improved, really atmospheric and absorbing....I have a Premium. Once I fix the sound call outs it will be a solid game
Thank you Lyman and Stern!
Cleland is awesome.
The Stern is operating now, I can't believe I'm saying this, but I'll have no problem buying a theme I like from day one versus waiting until code is done.
Great job Stern!
Quoted from iceman44:
My TWDLE came home around Nov 2 last year. So, it took 9 months until the game was close to finished. That seems about normal and I'm good with going on that journey and having the machine sitting in my home. As long as they get it done.
Quoted from centerflank:
Cleland- if you want me to go on a 24 hour bender watching TWD episodes for some fun one liners, I'm up for it
Thanks, centerflank but I think I'm good. I just compiled all my sounds into one folder and there's over 5,000 of them
Many of the iconic ones will stay, but I think I will try to inject some fresh new ones into the new code. Also, opinions are welcomed but will not necessarily be implemented. I think I'm going to cut the Merle "Bunch of Pu$$!e$" line and try something else. I already remixed the match sequence for more bass in the thunder without clipping. I'm thinking for the tilt sound to be mixed with "Time for you to leave A$$hole" sound byte too.
Cleland is awesome.
For some reason I have a feeling he wasn't asking
Quoted from Eskaybee:
Already watching,,,,,,Merle "maybe a winter in the sticks put some hair on his balls"
Don't you dare cut the bunch of pussies line! my kids think it's hilarious!
I thought I heard Lyman wasn't working on this anymore. Anyone know who really did these updates or are we assuming it is Lyman?
Quoted from judremy:
That's old news. There was a point where he stopped working on it (so he could work on other game(s) presumably). It was temporary.
Lyman owns Twdle, so he's going apeshit on it himself or pushing his underlings to finish it. Stern legal screwed Lyman out of his original work, so he's back to finish the job.
Yeah, I should have known.
Got that one, and noted on the bunch of P's line...I'll put it in another place to mix it up
Quoted from underlord:
I'm having a Lygasm will giving her a Cleland Steamer.
I love you guys! ( Big Bro hugs!).
Bro Hugs back. I Will be picking up a new keg of Stone IPA for my Kegerator and work throughout the weekend
