Quoted from Tacosid:I haven't. But that one switch is the only thing not working. Could there be a fuse that just controls that one switch?
I see what your saying. You have the 24v on,everything else...I wouldn't think there was a,separate fuse just for that.
Still, I would certainly check thru them and make sure they are correct values etc as a,precaution.
Without the wiring diagram in front of me, kind of hard to know. When you get the one you ordered, that should help a lot.
You could still have a broken or loose wire/connection elswhere, or a burned out/stuck coil...
It just seems very odd that it was working fine until you lifted playfield. That's why I keep going back to thinking its something that got messed up when open. Hence the mangled switch.
There is a possibility that the switch got mangled causing a coil to be stuck on until it burned out; so now switch is fixed, but coil is bad. But I would guess you most likely would have noticed a hot coil burning up, maybe not.
Best thing is going to certainly be look at diagram and see everything that is hooked into that. Then you will know all other areas to check.
