We have made a short run of these Razor Crest shooter rods and we are making them available now.
The matching shooter plate will also be a metal casting which will be available mid summer but the shooters themselves are ready to go now.
We have tested scale and this set up is the best fit and finish. The shooter is a one piece aluminum cast with a steel base protector and accurate blue accents.
You will simply have to remove the stock shooter rod and slide this one in its place reusing the stock housing.
If you would like to wait till late summer we plan on offering a complete housing like our shifter shooter mod.
Thanks for checking it out an for your support.
