Excellent! Star Wars has become one of Stern's best coded games to date Very impressed with the code support on this one.
Premium / LE read me
LE/PREMIUM V1.03 - May 8, 2018
NOTE - If you are seeing the ball bounce out of the inner loop after shooting
the hoth / video mode shot, please make sure your center post in the back
of the loop is adjusted flush with the playfield.
Moved to System 2.01:
- Improved audio stability.
- Added AD_TILT_DEBOUNCE adjustment. Number of ms to debounce tilt bob.
Defaults 1000ms, consider using 450ms for tourneys.
- Improved LED refresh rate and blink consistency.
- Improved reporting of shorted General Illumination bulbs and sockets.
- Extend TIMED PLUNGER adjustment range to DISABLED or 1 - 300 seconds
- Correct minimum firing time for flipper coil when an EOS switch is
inconsistent or poorly gapped
Fixed:
- Fixed an issue where shooting the Accelerator will now spot you a combo shot
if it was lit on the left to right horse-shoe shot.
- During the last phase of ESCAPE FROM HOTH the small screen was showing the
wrong background.
- Tie Fighter Multiball Jackpot sounds were not bringing the music back
correctly.
- Fixed the Hyperspace Hurry up tune. It will no longer be quiet when it
loops.
- Fixed Holotext sounds. Sometimes they were not playing correctly.
- Fixed a couple of misspelled words in the display.
- Points were not being awarded correctly in Hyperspace Multiball.
- LIGHT VIDEO MODE is no longer offered on CHOOSE YOUR PATH if it is already
lit.
- Fixed the map number of the upper shooter lane switch in diagnostics.
- Removed ability for ESCAPE FROM BOBA FETT to start while other
modes were running.
- The Custom Message feature will now show all three lines correctly
New:
- Added Game Over Lamp effects
- The ball is now held during the DESTROY THE DEATH STAR, ESCAPE FROM
HOTH, BATTLE OVER ENDOR, and ESCAPE FROM TATOOINE final fanfares.
- Added Hyperspace Multiball Total effect for the holotext.
- Added Loop count mode to accelerator test in diagnostics. When the ball(s)
have looped the count to zero all the balls will exit.
- Added some lamps effects and shaker effects for Hyperspace Multiball awards.
- Added adjustment for FLIPPERS END BONUS SOUNDS. Defaults to YES.
- Added overrides to the HOME and DIRECTORS CUT INSTALL options:
- PLAY MUSIC IN ATTRACT MODE - YES
- PLAY AUDIO IN ATTRACT CLIPS - YES
- FLIPPERS END BONUS SOUNDS - NO
- FREE PLAY - YES
- HSTD INITIALS - 10 LETTER NAME
- Added Holotext award for Hyperspace Multiball awards
- Added a lamp effect when an ESCAPE FROM BOBA FETT shot is added.
- Added adjustment to turn off topper attract sounds separately
Tweaked:
- Added some coils that were missing from COIL TEST.
- LIGHTSABER DUEL now only requires defeating Vader once per JEDI MULTIBALL
play thru. Once completed it will not be started again until the player
completes Jedi Multiball.
- Stopped the timer sound effects on the FORCE targets during the four
mini-wizard multiballs (ESCAPE FROM HOTH, DESTROY THE DEATHSTAR, ESCAPE FROM
TATOOINE and BATTLE ABOVE ENDOR) after ADD-A-BALL is awarded.
- If VIDEO MODE is started while HOTH and HOTH I are lit, we now spot HOTH I
as being complete, and increase the VIDEO MODE LEVEL before play begins.
- Greatly improved catching and holding the ball in the horseshoe loop for
modes like LIGHTSABER DUEL, HYPERSPACE HURRYUP, HYPERSPACE MULTIBALL and
others.
- Improved the timing of when the exit diverter opens to allow balls out of
the Accelerator.
- Added final DEATHSTAR shot accelerator hold effect to ENDOR mini-wizard
multiball.
- Improved ball search to use all the devices.
- Improved accelerator logic to be more responsive. Also it will recover from
weird scenarios more readily. For example when two balls collide and fall
off the loop. Also the Accelerator is less likely to be confused when
multiple modes need to use it at the same time.
- Improved Fork-Ramp timing to let the ball out as needed. If the ball hops
the ramp and the loop isn't expecting it to be there, the ramp should lower.
- Tilt will now lower the ramp to let the ball out as needed.
- Increased Hyperspace Multiball jackpot values.
- Tweaked some sound priorities
- Increased scoring for Light Saber Duel
- Jedi Multiball was redefined and improved.
- Now starts with 2 balls in play.
- There are two states.
- Attacking the Emperor. This state is blue.
- The Emperor attacks you. This state is red.
- When the lights are blue you have a total of 9 shots to complete the
multiball. These will be in 3 sets of 3.
- Each set of three has a timer.
- Increased how long the last players scores are displayed in the attract mode
- Improved the volume of several sounds and speech calls
- Added sounds to medal presentation at the start of Jedi Multiball
- Shoot again light was sometimes not seen during Jedi Multiball when it
should have been.
- Improved randomization of BONUS video clips.
- Added more sounds for the topper
- Changed the attract topper adjustment so the owner can change the attract
interval time from 5 to 60 minutes. Or the adjustment can turn it off during
the attract mode.
Hmmm - "Added more sounds for the topper
the attract mode."
The Topper lives .....
Quoted from PinBalt:Hmmm - "Added more sounds for the topper
the attract mode."
There is a topper motor adjustment as well, don’t recall seeing this previously.
Quoted from Psw757:There is a topper motor adjustment as well, don’t recall seeing this previously.
Motor adjustment? Maybe I missed it...I hope so! Can you provide the text?
Quoted from dnapac:Motor adjustment? Maybe I missed it...I hope so! Can you provide the text?
I didn't see that either. I sure hope there's a motor in the R2D2 topper to allow it to rotate back and forth. For $500 and considering how long its taken to develop / get approved that feature really needs to be in it.
Go into menu and SW adjustments, there is a setting that says R2-D2 motor, It wasn’t in the read me text.
Quoted from Psw757:Go into menu and SW adjustments, there is a setting that says R2-D2 motor, It wasn’t in the read me text.
Haven’t updated yet...so stoked! Thanks!!
Quoted from PanzerFreak:LIGHTSABER DUEL now only requires defeating Vader once per JEDI MULTIBALL
Jackpot
YES! Sounds like Stern will be getting another few hundred...or five from me.
Great update! Downloading now. Star Wars keeps on getting better! Thanks Dwight, Steve and crew @Stern!!!
Marc
Quoted from PanzerFreak:YES! Sounds like Stern will be getting another few hundred...or five from me.
A motorized R2-D2 topper if done properly could be the best topper built to date. Could even be better than the CE JJP potc ship in a bottle.
Quoted from Psw757:A motorized R2-D2 topper if done properly could be the best topper built to date. Could even be better than the CE JJP potc ship in a bottle.
Agree! Lots of cool possibilities. Makes perfect sense to have R2D2 be the topper with the X-Wing cockpit view on the LCD and R2 sticking out of the top of Luke's X-Wing in the films.
SW Pro Read Me:
PRO V1.03 - May 8, 2018
Fixed:
wrong background.
correctly.
loops.
lit.
modes were running.
New:
- Added overrides to the HOME12 and DIRECTORS CUT INSTALL options:
- FREE PLAY - YES
Tweaked:
- Added coils that were missing from COIL TEST. Also several coils needed
their coil numbers corrected.
others.
- Made Jedi Multiball start with 2 balls in play.
should have been.
the attract mode.
I like what I see!
Looks like a great update...hope to get mine updated tonight. Very glad to see they addressed Lightsaber Duel and video mode repeats. Horseshoe lock timing is greatly appreciated as that is something my machine struggles with. The rest is frosting on the cake. Delicious, delicious frosting. Mmmmm......
Love this game!
Stick should be formatted to FAT32 with nothing else previously on it.
Unzip the files, open folder, grab all three parts from the folder and drop it into your flash drive.
Game will recognize USB after these steps are done.
Love the new end-of-game light show!
I usually do the quick with no verify. I’ve done full with verify in the past and it took multiple tries to finish the update.
Quoted from Ccondo:That did it, I had my stick formatted for ExFat. what is better, quick or full update?
Always do the quickest way, no verify. Other ways just ass a ton of time
This page was printed from https://pinside.com/pinball/forum/topic/new-star-wars-13-code-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
