My Simpsons Pinball Party had a sound problem, so swapped in a new Rottendog MPU board. But it seems I've traded one issue for another.
Now the bottom right flipper is not working. The upper right flippers still work fine. All flippers were working fine with the original board.
I've checked:
- The flipper coil works fine in test.
- The right flipper button doesn't work in the test menu, or register in switch test. So looks like a switch problem.
- I've checked the switch with a multi-meter and it's good. The wiring looks fine.
- The second stage in the cabinet switch tests OK, hence the upper right flippers working fine.
Seems the problem is with the switch not registering with the MPU board. Possible I have a fault on the new Rottendog board? What's the likelihood of that?
Any other suggestions?
IMG_20220829_220738 (resized).jpgIMG_20220829_220817 (resized).jpgIMG_20220829_221625 (resized).jpgIMG_20220829_221642 (resized).jpg
