After the holiday shipping rush, I am going to start sending you mine.
On a firepower, it'd be the 5101, which is the chip just to the left of the battery holder, turned the opposite way to all the other chips.
I "played" a bit with Rob´s NVRAM-Adapter. Rob really did a great job in designing the hardware - and I know, what I am speaking of, because we also produce NVRAM-Adapters since some years.
To make the anypin-adapter more "universal" also for Gottlieb System 1, I strained my head and made the schematics. My idea was, that you use the anypin-adapter in the 6264-configuration and simply put the anypin-adapter in a "daughter board" specially designed only for GOTTLIEB System 1.
In theory it must work, but at first I let make a prototype now and make some tests.
@Rob: I will keep you informed, when my tests have been successful.
See attached file of the layout.
Have fun
- Ingo
NVRAM-SOCKET GTB SYS1.JPGQuoted from german-pinball:I "played" a bit with Rob´s NVRAM-Adapter. Rob really did a great job in designing the hardware - and I know, what I am speaking of, because we also produce NVRAM-Adapters since some years.
Have fun
- IngoAwesome Ingo, thank you!!
NVRAM-SOCKET GTB SYS1.JPG 38 KB
Can't wait to try it out.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
Have fun
- Ingo
Assuming u2 is a tri-state buffer? Honesty I'm surprised someone else got around to working on this System 1's don't get a lot of love, so at least it means there will be some options for nvram on System 1 machines in the near future. I had tried testing my prototype in a Bally-35 mpu but then realized I was going to likely need to combine the OD, /CE and R/W pins there to get the enable signals for the buffer. The 5101 on the System 1 has OD and /CE permanently tied to ground though, so I'd think you could probably just combine CE2 & R/W (maybe what u1 is for on your board). Then if someone plugs it into something other than a System 1 mpu then they would just expect it to not function.
Hey Rob, I believe my Fishtales needs to be soldered in order to use your product. Can you send me a PM telling me what I need to do in order to get the board to you?
Quoted from spag256:Hey Rob, I believe my Fishtales needs to be soldered in order to use your product. Can you send me a PM telling me what I need to do in order to get the board to you?
Just pack it up and send it to me. Address is on the website for USPS.
Rob Anthony
Pinball Classics
This page was printed from https://pinside.com/pinball/forum/topic/new-product-announcement-anypin-nvram-no-more-batteries/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
