All I could think of when I saw this picture was, "8 year-olds, Dude..."
This.
This sounds a bit scandalous, doesn't it?
Was that the one with Thomas Jane? That's the good one, in my mind.
It would be difficult but not necessarily impossible. Send me some info on the show, plz
Quoted from luvthatapex2:I am intrigued by this single board PC/SSD mounted in the head that you'll be using. Got a link to something similar that can drive the P-ROC?
That depends on what you're doing with your pin. If you plan on running PinMame to keep your stock rules available, then you're going to need a fairly strong PC to drive it. If you're planning on simply running your own software all the time, it doesn't take much to run a P-ROC at all. For something off-the-shelf, you can use a BeagleBoard. From the talks I've had with a few P-Roc'ers, the Raspberry Pi doesn't quite make the cut, though, unfortunately.
Yeah. The one we're leaning towards right now is honestly way overpowered for a pinball environment, but it is really affordable and easy to work with.
You guys have made it pretty apparent that I need to watch more movies...
