I posted this in the TAF thread as I was going back and forth with a few members and wanted to ask the broader community. I usually keep things as close to original as possible but discovered if you use frosted glass spray paint on clear pop bumper bodies its has a pretty cool look as opposed to the ugly looking white opaque OEM bodies. The problem is the clear bodies produced by Zitt are slightly shorter maybe by like an 1/8 of an inch and when you put the bumper caps on them the #555 bulb touches the caps and I am concerned about the heat from the bulb. Also being more of a purist I stick to incandescent bulbs, I have not jumped on the LED bandwagon as I prefer the look.
1) if the game is in a HUO environment and is not sitting on all day is the heat from the bulbs that much of a concern
2) are there shorter versions of a wedge bulb that will fit inside the bumper body that would work
3) I thought about putting a silicone o-ring on the inside of the bumper caps to build them up a tiny bit any thought on that idea would help
