(Topic ID: 186589)
***NEW*** PIN STADIUM Pinball LED lights Mod Announcement!!!
By pinstadium
2 years ago
  • 5,700 posts
  • 472 Pinsiders participating
  • Latest reply 7 hours ago by Chappie101
  • Topic is favorited by 144 Pinsiders
Topic poll
“What do you think of the new Invisi-Shields?”
  • Great idea (want them) 25 votes
    25%
  • Love them(own them) 48 votes
    48%
  • Not sure 26 votes
    26%
(99 votes)
This poll has been closed.
There have been 2,214 images uploaded to this topic. (View topic image gallery).
There are 5700 posts in this topic. You are on page 99 of 114.
#4901 5 months ago
Quoted from mandelbloom:
yes I am guessing it touched the base, lesson learned I guess. Wish is just blew the fuse but for whatever reason seems like more damage was done
Usually it’s just a fuse if not a simple transistor is all it will be. Check the manual but it’s just one of these type normally or the folks at Pinball Life will help you with their great customer service:
https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=tip121
I hope this helps.
#4902 5 months ago
Yea I am quite confident its the transistor. Deciding if I should take on the repair myself, have a pro coming Monday. My sparky also locked on, but I think i twas a coincidence as I have read that can happen when the play field is lifted.
#4903 5 months ago
Very rarely does this happen but when things are touching you never know. But the transistor is less than $2 to replace. You will need to pull the board out and desolder the old and then put the new one in.
Always remember that the alligator clips are for those that want an easy simple semi-permanent connection they can remove if they sell or trade the machine. They can then easily move it to another machine. You can always snip the clips off and solder it permanently. I hope this helps.
#4904 5 months ago
Quoted from pinstadium:
Yes, I may indeed solder them once I am happy with the locations just to be safe. What about wiretaps for a future option? Just a thought.
Anyhow I think that there may have been two unrelated events as the sparky seems to be a known issue! Lots of people have had them fry when opening the coin door and then turning the game on, even some had some flashers stay on! So I do believe I shorted the flasher as it wasn't working when I tested the game and then the fuse blew, but the other stuff may have been me working on that game oh well.
I already have the transistors ordered and the new "and apparently Improved sparky coil" ordered. But deciding if I will tackle the transistors myself as my soldering skills are average at best right now getting better
Adam
#4905 5 months ago
Adam
I think that it may not even be related to the install of the clips it sounds because normally if you do it wrong it just blows a fuse. Sounds like you are taking the right steps to replace it regardless and should have it resolved. Keep us posted.
#4906 5 months ago
Hello,
On the topic of IM, with the Fusion, you you can select the colors for each mode? Can you select the intensity by mode as well?
Thanks,
Mike
#4907 5 months ago
Yes indeed maybe ... though I guess in theory had I never messed with the game the unrelated event likely wouldn’t not have happened lol
#4908 5 months ago
Quoted from mjruser:
Hello,
Thanks,
Mike
It’s not mode specific as the game will control the modes that trigger the flashers and then with Fusions you can select the colors and brightness each time that bulb fires.
#4909 5 months ago
One of the things that makes the Fusion product so powerful is it is running very advanced software coding behind the scenes to calculate the ultimate light show sequencing that enhances any mode as you so desire. Very cool stuff built into this technology and it's very apparent when you see them in action on your machine. Breathtaking results guaranteed and flasher colors you never thought possible now available in the palm of your hands.....
#4910 5 months ago
If anyone want to see the Pin Stadiums in action on Alien check out the @deadflip stream live now: https://www.twitch.tv/deadflip
We have the GI set up on all green in the app and the UV+Glow triggered by the Xenomorph magnet. Worth checking out!!
#4911 5 months ago
One of the things that makes the Fusion product so powerful is it it running very advanced software coding behind the scenes to calculate the ultimate light show sequencing that enhances any mode as you so desire. Very cool stuff built into this technology and it's very apparent when you see them in action on your machine. Breathtaking results guaranteed and flasher colors you never thought possible now available in the palm of your hands.....
I can vouch for this, especially on my MMR. I noticed a lot of cool effects happening. For example, when you light up the extra ball after the second castle, everything goes dark except the Fusions flash red. Not sure if red is the default color for Fusion, or it is using one the flashers that I have set to red, but regardless, it's just a striking look. Likewise, when starting a Multiball Madness(hopefully with more than a few modes), the cycling of the lights on/off to highlight each Multiball Madness jackpot shot at the start, is really cool. Then there is the multi-color light show for things like Merlin's Magic and the UV+glow when destroying a castle. I especially love how I was able to tailor the Fusion to certain shots on my machine. I have a blue lighted dragon mod on my left ramp and blue flasher tied to it. Then red on the right ramp for the stock red dragon. Making those shots is so thrilling now(you can you say it's a Song of Fire and Ice ).
All the same goes for my ST as well. It's not just the default playfield lighting, but the overall event driven light show too. Pin Stadiums are cool, but Fusions are where it's at!
#4912 5 months ago
Quoted from PWhiz:
You have really had the chance to experience them in person on your owne machines and what he is describing is dead on exactly you can expect for your machine. I think you have done an excellent job explaining them by also taken the extra time to dial them in to your liking with the mods you described. The videos he posted up before I’m this thread are worth checking out so that you can see what he is referring to regarding the Fusions.
#4913 5 months ago
Tonight deadflip for fun played a game of Alien with the Pin Stadiums turned off per the Twitch chat request. He said he could not see the ball at all and screamed for help for someone to turn them back one lol!! Ken (Galloping Ghost Repair guy) was very helpful in demoing the lights on/off and adjusting to all the different colors. Check out the replay of the stream to see this. Really great demo of them. Here is a pic of when Jack turned off the Pin Stadiums!!
#4914 5 months ago
Here are some other color settings they used.
91606513-C559-4AB9-9F3A-DD6128B22FE5 (resized).pngB5570CE8-C989-4F3C-AB3F-2A2EA275085C (resized).pngC124C526-1BF4-4AEE-B322-506C88C22E1B (resized).png0BC13A37-ED9E-4427-98D2-A1B9DB99ED5C (resized).png
#4915 5 months ago
Another of them OFF
#4916 5 months ago
22E7FF16-09E6-4B30-B713-4F73AF175639 (resized).jpeg2F0F561A-E07E-47B8-AF8D-6EE53B7FD999 (resized).jpeg
#4917 5 months ago
#4918 5 months ago
Huge difference on Alien and absolutely so happy to also have them on JJP Pirates as I was able to remove all those ugly Spot lights
#4919 5 months ago
Quoted from BladeFury:
Huge difference on Alien and absolutely so happy to also have them on JJP Pirates as I was able to remove all those ugly Spot lights [quoted image][quoted image]
Nicely modded.
#4920 5 months ago
Thats a perfect example of Alien and POTC. Yes most everyone is pulling out the spotlights on POTC once they have the Pin Stadiums installed since there is no need for them and they have no effect after the install.
#4921 5 months ago
This is a great example for lordhelmet and review of the Fusions on POTC too. Check out the video of them in action: https://pinside.com/pinball/forum/topic/new-pin-stadium-lights-official-announcement/page/82#post-4924983
#4922 5 months ago
villathrills was one of the first to install them in JJP POTC and he took a pic of all of the spotlights that are easily removed:
https://pinside.com/pinball/forum/topic/new-pin-stadium-lights-official-announcement/page/70#post-4701140
#4923 5 months ago
AF3F9E2E-D079-43E1-B77C-1F9F753B1B93 (resized).jpegD75AC85E-67A5-401F-81A2-D0BCC1F19588 (resized).jpeg
#4924 5 months ago
Side by side
#4925 5 months ago
Fusions are in stock in available for immediate shipping: https://pinstadium.com/product/pin-stadium-fusion/
#4926 5 months ago
I had a question asked by a customer as to the best trigger for the UV+Glow on GOTG. Currently many use the Orb inlay but there are many other flashers on the machine if you cycle through in Settings/Diag/Lamps/Flashers if you want to see all of the available options. I would not be surprised if you may find a better one you like too. Post it up for for us if you land on another instead. This technique of using the settings is VERY helpful and a must if you are installing Fusions.
#4927 5 months ago
#4928 5 months ago
For Stern machines this is so very helpful in determining your available flasher location. Open the coin door and to into: Settings/Diag/Lamps/Flash
Cycle through them and you will see all kinds of options to trigger the Pin Stadiums UV+Glow or Fusions/Orion's Belt flashers from!!!
#4929 5 months ago
Will the upcoming Blur completely remove the stripe effect? If so, when will these be available. Thanks!
#4930 5 months ago
Quoted from Only_Pinball:
Yes that’s the goal!! Which is why I’m taking my time fine tuning it with precision. As far as the timeline goes I am working to get the majority Pin Stadium audience with the Hovers first since the BLUR need those to attach to the accessory port on them. I’m mapping the Pin Stadiums to Hover ratio internally on my end.
Once the Hovers continue to spread then I will be able to narrow down a better timeline. This will also allow for a very efficient production process too since it’s all being done in the Pin Stadium factory
#4931 5 months ago
So anyone that is still considering Hovers, now is a great time to order them!! I expect the first few of the this production run to start leaving out of here likely next week for those who have your orders in already. They will be shipped in the order received and I will email you tracking information when they go to leave out of here.
#4932 5 months ago
Sounds good. I will be following to see how this shapes up. My MMr could really use some more lighting. Thanks for your time.
#4933 5 months ago
You are welcome and very glad to help! Also keep in mind that you could get the Pin Stadiums now and then the Hover/BLUR are upgradeable at anytime on the kit you purchase which is the nice thing about how the Pin Stadium design model works. Here are the results of what you can expect as the product sits now!
mmr_pinball_lights_led_kit_after (resized).jpegmmr_pinball_lights_led_kit_before (resized).jpeg
#4934 5 months ago
Here is another customer's MMR Before and After pics too!
mmr_pinball_lights_led_kit_after2 (resized).jpgmmr_pinball_lights_led_kit_before2 (resized).jpg
#4935 5 months ago
Those are mine before adding even more lighting recently. What can I say, Pin Stadiums inspired me. This machine has never looked more dynamic whether I'm playing it or not.
Note: Try as I might, I just can't seem to capture the true color vibrancy of the purple/green on the castle on my iphone. The green especially looks way more washed out than in person.
Going to try and get some better video of it in action when I can. Last one I took, I hadn't finalized flasher placement, and before I added extra lights/mods.
#4936 5 months ago
#4937 5 months ago
Quoted from PWhiz:
Going to try and get some better video of it in action when I can. Last one I took, I hadn't finalized flasher placement, and before I added extra lights/mods.[quoted image][quoted image]
The really nice thing about your pics is it shows how the Pin Stadiums "Invisi-Look" feature really takes effect by removing the glare from the lighting from the speakers and in the room reflecting on the playfield glass. In my opinion one of the best pics I have seen yet for demonstrating this!!! Well done and I will be saving these for sure.
#4938 5 months ago
OK, here's some more video as promised.
#4939 5 months ago
Quoted from PWhiz:
Well first off that was a great ball he had on the video and secondly it allowed for a prime example of the Fusions on your MMR!! I think that you have them dialed in really nicely and well orchestrated as a result. Thank you for posting this up for us all to see. Very impressive and I’m sure it looks even better in person.
#4940 5 months ago
Another really great machine that plays like a beast with killer artwork that is brilliantly revealed after the Pin Stadium install. I will let you have the imagination on what is possible with this... Spooky ACNC
#4941 5 months ago
Here is a clear unedited pic of ACNC in a completely dark room.
#4942 5 months ago
#4943 5 months ago
I have had a few questions about how much ACDC will benefit from the Pin Stadiums being that parts of the machine have some brighter sections. This in fact makes for more contrast in the darker areas thus resulting in powerful results that are sure to please!! There is a reason ACDC is a popular game to install Pin Stadiums on....
#4944 5 months ago
#4945 5 months ago
I have them on my AC/DC...huge difference. I removed the spots and it improved visibility of the PF, which is another nice benefit...
#4946 5 months ago
Quoted from snaroff:
That's awesome and removal of spotlights makes for a much cleaner and visually appealing playfield. Thanks for letting us all know and also for your support for the product snaroff
It's really neat to see this machine with the concert lighting it deserves!!
#4947 5 months ago
Tune in tonight as FlipNout Pinball https://www.flipnoutpinball.com will have guests Joe Katz, Keith Johnson, and Eric Meunier from Jersey Jack Pinball on the stream!!
You can check out the Pin Stadiums "live" in action on Willy Wonka at 7pm CST or 8PM EST. Even better Pinquest and Pin Stadium are going to do a challenge for Ken and Bill (likely Steve Bedi too) where they can win 5,000 bits if they get meet certain goals that we have set for them.
Also after hours "call in" as always so you can talk to the crew including JJP yourself!! Check it out here:
https://www.twitch.tv/flipnoutpinball
#4948 5 months ago
Stream is live!!! Feel free to jump in and ask questions to JJP directly. They are covering a lot of things..
#4949 5 months ago
Oktoberfest artwork and playfield comes alive after the Pin Stadium install. Big impact and results on this game!!
#4950 5 months ago
Addams Family has always been a big favorite for collectors installing Pin Stadiums. Really impressive results. Literally like night and day.
BCC9098F-A7AC-4115-96A5-944C634A61B6 (resized).jpeg1E611B97-9D7D-477A-AF25-02B6C2D962F3 (resized).jpeg
$ 2.50
Pinball Mod Co.
