(Topic ID: 186589)
***NEW*** PIN STADIUM Pinball LED lights Announcement!!!
By pinstadium
2 years ago
  • 4,838 posts
  • 409 Pinsiders participating
  • Latest reply 41 minutes ago by pinstadium
  • Topic is favorited by 144 Pinsiders
Topic poll
“What do you think of the new Invisi-Shields?”
  • Great idea (want them) 25 votes
    25%
  • Love them(own them) 48 votes
    48%
  • Not sure 26 votes
    26%
(99 votes)
This poll has been closed.
There have been 1,718 images uploaded to this topic. (View topic image gallery).
There are 4838 posts in this topic. You are on page 89 of 97.
#4401 42 days ago
Fusion orders from over the weekend are shipping out toady and will be on there way. Just letting everyone know as it seems like this weekend was Fusion Fest or something as a lot of orders came in even more than normal. Tracking information will be send to your emails shortly if you have not received them already.
#4402 41 days ago
Anyone had issues with the Magna-Mount coming loose from the side of the cabinet?
A couple of mine do this periodically, seems to be when I've had them on for hours at a time. The magnets are warm/hot when this happens. The two that do this are the sets with the same brand of side art blades. The third set I have has the Stern factory blades, and they don't come loose.
The ones with issues have TiltGraphics blades, they were wiped clean with alcohol and allowed to dry prior to installation. Not sure if I need to scuff the side art a bit to give the adhesive a better surface to tack onto, or if 100% brightness for hours at a time will just cause this...
Thanks all!
#4403 41 days ago
Quoted from Kronlar:
Thanks all!
Tilt graphics art blades definitely have a different finish/texture to them. Not like a smooth decal so I’d assume they don’t contact/adhere as well with them. But if Hover ever becomes available then you won’t have to worry about that anymore
#4404 41 days ago
Thanks all!
It rarely occurs, but I have seen this happen before in a few instances and one time it happened to me even. This is due to a "freshly" printed art blade with a certain amount of die/color (just a rare combo) and they are out-gassing which breaks down the adhesive. So the easy fix is for you to email me and I will send another set of Magna-Mounts to you as you will need them due to the fact that once the bond breaks it will not re-adhere properly.
When you install the new ones, be sure wipe it with rubbing alcohol again and let the mount sit for 48 hours before mounting the light bars. Be sure to squeeze it firmly with your fingers from the outside and inside of the cabinet when mounting this one. This will allow it to fully cure thus negating the out-gassing from the new art blade. Most art blades are not fresh and sit around for a little while, and when they do they go through this outgas process but you happen to get some really fresh ones. The Sterns have likely been stored for a bit. I hope this makes sense and email me with any questions along with your order number/name. I will get you taken care of.
#4405 41 days ago
Sounds good. Thanks!
#4406 41 days ago
They fall off of my TiltGraphics blades also and mine were on over a year before I bought my Pin Stadiums... But I am just checking this thread daily for the release of Hover and then I don't have to worry about it anymore. I was offered a new set of Magna Mounts as well but would rather just wait for Hover and take the magnets off completely.
#4407 41 days ago
Quoted from calfdemon:
If that occurred after that time then the fix is to clean and put a new set of Magna-Mounts on and apply "extra" pressure then sit for 48 hours to be sure it's done. But yes, "Hover" will be the ultimate solution in many ways.
#4408 41 days ago
By the way, HUGE stream "On Tap" tonight with Zach from FlipNout Pinball and live hosts Ken/Bill from Special When Lit with Josh Kugler of American Pinball (he will be there playing and answering questions) streaming new code on Oktoberfest WITH Pin Stadiums!!
You have go to see the results on Oktoberfest. It is now even more "Special When Lit" woohoo!!!!
https://www.twitch.tv/flipnoutpinball
#4409 41 days ago
#4410 41 days ago
Quoted from pinstadium:
Last night was an awesome stream and definitely worth checking out!!
Josh covered all the bases and the Pin Stadiums really brought Oktoberfest to life: https://www.twitch.tv/videos/424978567
#4411 40 days ago
twitch_bg_pinball_led_lights (resized).png Start following us on Twitch we will be hosting the most popular streams and will be streaming "Live" the Pin Stadium products so you can see them in action along with some exclusive giveaways. "Seeing is believing" with our products as you all know.
Follow us by tapping the heart icon from here on the top right of the screen: https://www.twitch.tv/pinstadium
#4412 40 days ago
Here some requested pics on Iron Man getting the Pin Stadium boost!
#4413 40 days ago
#4414 40 days ago
After playfield view coming soon!!
#4415 40 days ago
And here are the "After" results of the Pin Stadiums lighting up this artwork to vivid HD brilliant quality!
#4416 39 days ago
That looks great. I am picking up an IMVE on Sunday. May need a set. I am going broke on stadium lighting!!!
#4417 39 days ago
Quoted from Bos98:
Oh cool!!! I really love that machine and the one in the picture is mine before the Invisi-Shields were invented, hence being able to see the light source from the lower camera view.
Now that I have installed the Invisi-Shields that is no longer the case. I am happy to help you light up IMVE and do it even better justice. The UV+Glow on the drone targets is epic to say the least. So that will be your right ramp flasher that you connect to.
#4419 39 days ago
Several have asked for videos of them in action on IMVE. Here you go:
#4420 39 days ago
Here is the exact location to trigger from if you want the UV+Glow to ignite when the drone standup targets are hit! It’s the right ramp top flasher.
#4421 38 days ago
Here is a cool post to check out. Jeff from TWIP www.thisweekinpinball.com bought an AFMR and installed a set of the Pin Stadiums on it. Check out his comments on it here: https://bit.ly/2VLg52d
58761A70-0298-4309-947B-804C28017186 (resized).jpeg7246114E-FECC-470F-9356-F5033E6E6D45 (resized).jpeg49B25EA8-997F-4AE1-B337-EAC3799758DB (resized).png
#4422 38 days ago
This is a good example of the difference you can expect on JJP POTC. One of the top sellers for Pin Stadiums and such a great machine to play!
#4423 38 days ago
#4424 38 days ago
#4425 38 days ago
BBBA537D-E66B-48D3-B4BA-843611F1975E (resized).jpegCC739F3E-E5F9-4C1F-A260-BAFC6710EDAB (resized).jpeg
#4427 38 days ago
Thanks Scott. Can you tell me does the Black knight sword of rage LE need a service port adapter or anything else for the fusions? do the fusions have built in shields or something as well?
what do i need?
#4428 38 days ago
Quoted from elf70:
what do i need?
It does "not" need a service port adapter, only CGC machines and most of the Bally/Williams WPC95 do need them. The Fusions have the Invisi-Shields built into it so you don't need to add anything when ordering the Fusions. It will have everything you need.
#4429 38 days ago
As part of a silent auction for Cycle for the Seas charity thanks to asoa this ecstatic winner got his first Pin Stadiums and put them on a Flash Gordon. I helped him over the phone to install them. When they came on for the first time his reaction was priceless!
Check out these results on this beautiful 1981 Bally pinball machine. Classic machines will give you one of the most dramatic results even seen with Pin Stadiums.
Most of these older pins don’t have flashers but since you can trigger the Pin Stadium’s UV+Glow flasher with any bulb, you now have some.
He used the “3x” flasher inlay bulb in the center of the top circle of lights in the middle of the playfield. Wicked sweet!!
01D17A56-50B6-4979-97C0-69AC446366D8 (resized).jpeg7C88B268-6084-44B2-A464-A5CE9E2F6230 (resized).jpeg
#4430 37 days ago
A good side by side example here!
#4431 37 days ago
Here is a full list of Features & Benefits for Pin Stadiums. This will get updated to the website also.
#4432 37 days ago
Updated version:
#4433 37 days ago
Gift Cards are now available! https://pinstadium.com/product/gift-card/
#4434 37 days ago
Is Hover coming out soon? Or is there a hiccup in getting these ready for sale
#4435 37 days ago
Quoted from PinRob:
No hiccup just making a small run this week for my machines to test before they enter official production and I offer the first run.
#4436 37 days ago
IMDN with Pin Stadiums is a huge difference! UV-Glow I like to trigger from the Pharaoh flasher but some use either of the lighting bolts in the center of the playfield, shaker motor, Revive spinner flasher, and many more.
#4437 37 days ago
The Revive spinner is actually a really good spot as the flasher triggers every time there is a rotation with the spinner which makes it even more rewarding along with a super cool light show.
#4438 36 days ago
#4439 36 days ago
#4440 36 days ago
This is the most popular and recommended location for the Pin Stadium’s UV+Glow trigger “right eject”. In fact this is where I even suggest Dwight Sullivan to install them in his SWLE. Very cool!!
#4441 35 days ago
#4442 35 days ago
Here is a nice example of a normally very dark machine. STTNG is really showing up in this pic:
https://www.instagram.com/p/Bxt3zLvlqX0/?igshid=mnhpte3s52za
8C122182-3EFF-457F-B4B8-210C1779E72A (resized).pngEE81DEAF-CFFC-499B-8D34-F554F0246B66 (resized).png
#4443 35 days ago
[quoted image][quoted image]
For Dialed In a few have asked me where is the best location to trigger the UV+Glow from. The QED guy is the best location as every time you hit him it make an electrocution/zap sound and the UV fires off for a super nice light show!
#4444 35 days ago
What's the status on the diffuser? I've gotten to the point where the rainbow light reflections are really grating on me. I have a few uninstalled sets of PS waiting for this feature.
#4445 35 days ago
Quoted from Cheeks:
Glad you mentioned this, the Hovers will have integrated into their design the ability to accept the Blur(diffuser) among other future Pin Stadium enhancements that come down the line in the future.
Basically you will be unlocking the next level of capabilities with the Hovers since it allows for many great things to come.
#4446 34 days ago
Here’s is another pitch black room pic of LOTR!
70A8712B-98A9-496F-A76F-9D4EE9FCA86B (resized).pngD8870CE6-1A94-451E-93FB-6BA841D597B9 (resized).png
#4447 33 days ago
The last few weeks have been very interesting and never would I have thought that the Pin Stadium products would have battled it out with each other, but take a guess who is now beating who?
#4448 33 days ago
Both of course are great products and nothing will ever take away from that as you can't go wrong with either, but customers have spoken that feature rich products are what you guys want. Thank you all again for the tremendous support and there is innovation always on the horizon for your Pin Stadium products!
#4449 33 days ago
The last few weeks have been very interesting and never would I have thought that the Pin Stadium products would have battled it out with each other, but take a guess who is now beating who?[quoted image][quoted image]
What I meant by this is that the Fusions have outsold the Pin Stadiums this month. The word is getting out now that a lot of Fusions are deploying into machines. Collectors are getting to see them in person!
#4450 33 days ago
Game of Thrones LE gets some fire on the castle walls and playfield!
87A3ED51-C354-4DF2-9FC9-6DEE22BDC45C (resized).jpegCB2A69ED-A77C-45A8-A596-065A676DA772 (resized).jpeg
$ 54.00
$ 27.50
The MOD Couple
6,500
Champaign, IL
$ 7,499.00
Little Shop Of Games
$ 86.95
$ 109.99
$ 87.95
$ 19.95
Trade
Sale Pending!
Altoona, PA
$ 7,499.00
Gulf Coast Pinball, LLC
$ 239.00
$ 84.95
$ 99.99
$ 129.00
$ 30.99
Lee's Parts
1,800
Sale Pending!
Cleveland, OH
7,395
St. Clair Shores, MI
$ 89.99
$ 26.95
$ 40.00
$ 89.99
$ 24.95
The MOD Couple
Metal-Mods
