Thank you for posting and for your list of help/suggestions. I have replied below with some tips and suggestions:
* Clearance is very tight, especially on the right side on my game.
I have installed them on CFTBL on my machine and designed them to fit on that machine during the creation process of the Pin Stadiums so I am familiar with what you can do to help. That cabinet is snug but clears and so when lifting the playfield if you slowly raise it and move left slightly it will help to clear that right side of the cabinet. The left ramp with the playfield down is the closest clearance of all of the games and that was what made me design the Pin Stadium with lower profile specs to accommodate this generation of machines also.
* It's not possible to route the flat cable anywhere hidden on the right side, due to the back panel design on CftBL. I might take a Sharpie and color the flat cable black to make it less visible.
CFTBL has an little different designed backboard and place of the of ribbon cable brackets is more important than most, and if you adjust the amount of slack in the cable prior to clamping them in the back you can then tuck them just about out of sight 100%. It may take a couple times to adjust the slack but it will help significantly.
* I wish there were connectors top-side so the LED strips could be easily removed when lifting or working on the playfield.
This was mentioned in a post prior for an operator on route that asked about this. The reason there is no disconnect at the end of the light bars is because I had tested it extensively with some high quality connection components and it made the ribbon cable area bulky and unable to be hidden and also created a weak point in the wiring system that was eliminated. As a result I redesigned the quick disconnect it so that you simply release the 2 cable clamps and unplug the GI/Flasher connections withing a few seconds if for some reason you need to remove the light bars completely out of the game(very rare that you would need to do this but it is an option). However what most do when servicing the machine is they tuck the light bars under a slingshot plastic or habitrail return so that they stay in place for easy maintenance. Each game will be slightly different but once you find the sweet spot it works really well and is quick.
* The LEDs are quite noticeably visible in my side vision when I'm playing the game right next to it, much more so than I expected. (I'm 174 cm, playing in a standing-straight-up stance.)
They were designed so that it would not be visible to the player or the machine next to you until you get a few games down, however if you are shorter then it may be slightly visible. CFTBL is a good example of why the awning system was system that way it was because it would not clear with the close clearances mentioned. However the good news is that we are in process of making some really cool add-on accessories for the existing Pin Stadiums one of which includes an optional awning that will be compatible with the light bars that you can add to your machine even this machine. Those are in the works and in testing/development as we speak along with some other great things that will work with your existing Pin Stadiums, exciting stuff coming guys!!!
* I found fine-tuning the color in the app to be finicky, and would like to be able to input R/G/B separately rather than using the palette.
I really, really like the end result in terms of lighting.
The color wheel for most is perfect, but if you are like me I like to gain granular control and really dial things in. The good news is that I have already built this feature into the app for you. On the top left side of the color wheel you will see a R, G, B (see picture below) and if you tap on that this lets you hone in the colors on a very granular level. You will love this and I use it a lot. It's sort of a hidden feature that many don't see since the color wheel is used the most.
Thank you so much for your order and support for the product along with your suggestions too. I hope this helps you and explain why these are used effectively not just in a personal collection but in your case out on route to help increase profits and the fun factor for public use games. If you have any questions please email me directly at [email protected] I am more than happy to help you out!
Scott
Pin Stadium
www.pinstadium.com
