**ONLY 100 being made in this Limited First Run. If they show "IN STOCK" then you are in luck and should purchase right away. DON'T MISS OUT as these will sell out Very Fast!!
ORDER HERE: https://pinstadium.com/product/neo-x-panels/
The COMPLETE Ultimate Light Show for your Stern Led Zeppelin, Rush, and Foo Fighters!!
VERY Limited First Run is being offered up here. If you are lucky enough to find this link and there is stock still showing, then you can place an order for this current Limited Run on ONLY 100 units. Ship time is 8-10 weeks. The sooner you place your order, it will put you at the front of the pack to ship as soon as they are ready. These ship in the order received.
Introducing Neo "X" Panels - Ignite Your Pinball with Rockin' Brilliance!
Are you ready to take your pinball experience to legendary heights? Look no further than Neo "X" Panels - the ultimate pinball lighting upgrade that will leave you speechless!
Choose Your Path: CoverBand or Concert Edition!
CoverBand Edition - Amplify Your Playfield and Cabinet:
Experience pinball like never before with the CoverBand Edition of Neo "X" Panels! These incredible panels deliver insane playfield and side cabinet wall illumination, replacing factory lighting if you have it. Get ready to witness your pinball machine in a whole new light as Neo "X" Panels outperform leaps and bounds!
Concert Edition - Unleash the Ultimate Concert Light Show:
For the true rock stars of pinball, the Concert Edition is the way to go! This version not only provides multi-colored flashers and multiple trigger points, inspired by the legendary Neo Fusion Atoms Orions Belt, but also works with all models (Pro, Premium, and Limited Edition) versions of Stern Led Zeppelin, Rush, and Foo Fighters! Whether you already have factory lighting or not, the Concert Edition will fulfill your wildest pinball dreams.
⚡ Limited Production Run - Don't Miss Out!
Act fast and secure your spot in this first Limited Production Run of Neo "X" Panels. There are only 100 sets available, and you wouldn't want to miss this chance to transform your pinball machine into a sensational concert stage!
The Power of Rock - Your Pinball Adventure Awaits!
Choose Your Edition Now:
CoverBand Edition or Concert Edition
Get ready to unleash the power of rock in your pinball machine with Neo "X" Panels! Elevate your pinball experience to legendary heights and rock on!
SEE THEM IN ACTION HERE: https://www.instagram.com/reel/CvnC2GMNnZW/?utm_source=ig_web_copy_link&igshid=MzRlODBiNWFlZA==
Scott
Pin Stadium
www.pinstadium.com
Foo Fighters (LE)
Foo Fighters (Premium)
Foo Fighters (Pro)
Led Zeppelin (LE)
Led Zeppelin (Premium)
Led Zeppelin (Pro)
Rush (LE)
Rush (Premium)
Rush (Pro)
Quick FAQs:
Q: What is the Concert Edition upgrade option?
A: These will have all of the same features of the Neo "X" CoverBand Edition, but you will get a huge upgrade with a highly advanced multi-colored flasher system (know as Orion's Belt) embedded onto each light bar. It will let you trigger up to 4 different flashers providing an outstanding mind blowing light show that will be sure to impress. These are the top performer concert effect without a doubt and will keep you coming back for more!
Q: I already have the factory side lighting or I have been waiting for mine to arrive or I am considering them, so how do these compare?
A: There is not comparison and you won't need them, as the Neo "X" Panels replace those lights panels and will completely dwarf the performance of the factory lighting, delivering an unmatched concert-like experience. The factory lighting has only 96 LEDs in comparison to the Neo "X" Concert Edition has over 1,400 AI designed, tuned, and syncing LEDs!!! YES that is NOT a typo either. These are a game changer that will exceed your expectations and then some!!
Q: Which Stern pinball machines are these Neo "X" Panels compatible with?
A: Yes, they are specifically designed for Stern Pro, Premium, and Limited Edition band-themed machines, including Led Zeppelin, Rush, and Foo Fighters and whatever ones come down the road.
Q: What do I do with the factory lights that I removed?
A: Put them on the secondary market for sale as this will cover your cost for the purchase of the Neo "X" Panels. Depending on what model Neo "X" Panel option you choose (CoverBand or Concert Edition), you will, in essence, get our product for free or at a very inexpensive price when you sell them. Do the math and you'll see. WOW!!
Q: Do I need the factory side lighting installed to use these?
A: No, not at all. You won't need it period.
Q: My machine is a Pro and does not have a panel to install these, can I still get these?
A: Yes, you will just use our Magna-Mount system!
Q: Does this really sync with the game's music and factory audio, and if so how?
A: Yes, these offer the tightest integration possible on this planet, syncing with all spectrums of the audio and music details like never before. It plugs and plays from the audio output on the Stern board, creating an immersive and mesmerizing gameplay experience.
Q: Do these already come programmed out of the box?
A: Yes, they will Auto-Sync 100% with your pinball machine once you connect them to the app!!
Q: How do they differ from other Pin Stadium products?
A: Neo "X" Panels offer enhanced features, including multi-colored flashers, Lumi-Motion, and more, delivering an ultimate concert light show for your Stern band themed machines.
Q: What makes Neo "X" Panels a must-have upgrade?
A: Neo "X" Panels provide unparalleled brilliance on the playfield, elevating your pinball gameplay to a whole new level of excitement.
Q: Can I customize the lighting effects with Neo "X" Panels?
A: Absolutely! The Pin Stadium app unlocks endless customization options, allowing you to create a personalized and mesmerizing pinball experience. Mesmerizing simply to use menus appear mysteriously that yo have never seen before in the app. Watch it come alive!!!
Q: How many units are available in the first production run?
A: We are offering only 100 units in this first Limited Production Run, so act fast and secure your panels now!
Q: What's the installation process like for Neo "X" Panels?
A: Installation is a breeze! Neo "X" Panels snap into place of the factory panel lighting locations and feature a simple Plug & Play setup.
Q: Can I backorder if they're sold out?
A: Yes, if our Limited Production Run is sold out, you can backorder them. But hopefully you did not wait so you can get them in the first run in 8-10 weeks.
Q: What's unique about the Lumi-Motion feature on Neo "X" Panels?
A: Lumi-Motion creates an auto-sync with the full spectrum music coming from your pinball machine, enhancing the immersive experience like never before.
Q: How do I unlock the full potential of Neo "X" Panels with the Pin Stadium app?
A: The Pin Stadium app gives you complete control over colors and brightness, letting you tailor your gameplay experience to your preferences. Once you connect to the Neo "X" Panels it's on!
Q: Will Neo "X" Panels improve visibility and reduce playfield glare?
A: Yes, just like all of our products installing Neo "X" Panels takes care of the playfield glare, providing unparalleled visibility for the best gameplay experience ever.
Q: Can I install them on other band-themed pinball machines?
A: Neo "X" Panels are specifically designed for Stern Led Zeppelin, Rush, and Foo Fighters machines, offering unparalleled brilliance and effects.
Q: Are Neo "X" Panels durable and long-lasting?
A: Absolutely! Neo "X" Panels are crafted with high-quality materials to ensure longevity and reliable performance for years of enjoyment.
Choose your ultimate concert experience - CoverBand Edition for amazing playfield and side cabinet wall illumination
OR
The Top Performing Concert Edition for a massive leap up with the full Orions Belt experience. Don't miss out on securing yours and embrace the rock and roll magic of pinball like never before!
1x Pair of Neo "X" Panel Edition Light bars
GI/Flasher Cables
2x Stealth Decorative Wire Panel Covers
"Y" Service Port splitter
Plasma Power Supply
Installation instructions
Free IOS and Android app for download
