Quoted from robey99:Are there any recommended settings for specific games? I tried searching on the website but it cannot find any games. Thanks.
Most of the recommended settings are on this thread, but since it's really up to personal preference so it's hard to really say what will look best for most . However if you can post up what machine you are installing the Pin Stadiums pinball mods on then I can give you a suggestion here. There is a science to getting what I feel is the best results as follows for best results. I will share my steps when I install them on a machine:
1. Turn off all lights in the room and make sure it is completely dark
2. Once connected to the Pin Stadiums in the app, turn the "Brightness" slider all the way to the right to 100%
3. Turn the "White" slider to the 0% which is all the way to the left
4. Then start moving your finger around on the color wheel to every color range (purple, blue, turquoise, red, pink, yellow, orange, green, etc).
5. As you move the colors around you notice that the artwork on the playfield will literally start to visually "pop" off the playfield and become noticeably vibrant. It's going to happen once you get into a certain spectrum. It's commonly (but not always) the color that is most dominant in the artwork.
6. Then once you have nailed down the colors, start to gradually introduce the "White" lights from 0% up to the desired level that you like. Most usually run anywhere from 35% to 100% depending on the machine.
I hope this helps you out!!
Scott
Pin Stadium
www.pinstadium.com
