Quoted from Whysnow:
happened multiple times, even after resecuring.
Same thing I have experienced when playing on route and the product falls into the game, rendering it down for the count.
Yep exactly that is a perfect example of how important it is to have them aligned end to end as the Magna-Mount system’s magnetic pull is calculated for that which creates central alignment.
This is a great opportunity to mention a highlighted point in the instructions which is even MORE important. A common mistake when doing an install is to take the mounts off that are already on the back of the light bars.
These are matched here at the Pin Stadium factory and if you reverse them that will shift polarity and cause this issue. When done properly they are solid as a rock which is why at at Pinburgh I am there to personally install them as everything is so important at this event.
The work that PAPA does to ensure that these games are in top top shape before, during, and after gameplay is insane. I love to see that attention to detail and am honored to be considered part of that.
