After following the pinwiki regarding ground row shorts I determined that the MPU was at fault. I just got my replacement board and want to make sure I don't fry that one as well. I have run through the entire machine and have not found any physical shorts, my question is, if I connect the new MPU with 206 and 209 disconnected, then testing the matrix from there, will that be enough to protect my new board from frying? Or is there another trick to try?
Thanks,
JLB
