I tried to make LED flippers work in B/W games years ago and I haven't seen the LED B/W flippers yet that PPS sells but the wires are probably outside of the shaft. Hopefully, the wires come out the back of the flipper so the wires can be routed through the playfield under a kicker or other object (the cheapest solution since it makes less stress on the LED wires and with minimal chaffing to the insulation though these issues can be fixed by protecting the wires with different colors of shrink wrap). If not and you're drilling through the nylon bushings, there's moving flipper parts that need to be routed around that the wires can hang up on.
Since I like mods that can be converted back easily to factory (with the exception of my 6 to 7 digit Gottlieb conversion), I'll try to explain the issues I ran up against as I found them, maybe there's a solution out there that I didn't see. The problem is in the design of the B/W flipper assemblies, they weren't designed with the idea of running wires through the flipper shaft and running a wire down the center is ideal for less travel damage to the wires. They use such a small shaft, when doing the things suggested (drilling or milling), the pawl will crush the shaft when it's tightened down to prevent movement. Then, you can't remove the flipper once any damage is done without cutting the shaft off. Milling worked the best for the wires but the shaft became weak and would twist at the milled area when the bat was being hit by balls.
Also, the milled area made it real difficult to hold the bat firmly to the shaft even though the shaft was filled with a good epoxy to hold the wires in place. So, the only way I could LED a B/W flipper is to leave the shaft alone and have the wires hanging loose, then you drill through the nylon bushing and fish the wires through (other than routing/drilling through a kicker area). The problem this creates is that there isn't enough travel room inside that little space between the flipper and bushing, so the movement of the wires will cause them to fatigue and break or the playfield will eventually saw through them as the flippers move back and forth. I've seen both happen in my testing so I abandoned that path.
A solution for this is to redesign a B/W LED flipper kit that has a larger shaft on the bat so the wires can slip down inside the shaft like I can do with the Gottliebs, a center rotation means less chance of wire damage. Also, 2 new larger inside diameter shaft bushings and a larger inside diameter pawl would need to be made. I was working on designing/making a B/W LED flipper kit but had to shelve it for other projects I was more interested in.
Steve
