Hi,
I've been preparing to do a playfield swap on my STTNG using a new Mirco playfield and have a couple questions to ask before I start installing parts on it.
1. I tried installing some metal posts on the new playfield and noticed that the holes for the posts are slightly smaller then those on the original playfield. The entire post won't go through the new playfield which is making me wonder if drilling the holes slightly larger on a new aftermarket playfield necessary / typical? It seems like that may depend on the playfield manufacturer from other threads I've read through. Also, if drilling is necessary do you recommend drilling from the top or underside of the playfield?
2. Would you recommend still installing Cliffy's and applying mylar in potential wear areas on a new aftermarket playfield? I'm assuming yes on the Cliffy's as many of us, including myself, install them on NIB games. For mylar I was thinking of putting a piece down where the ball comes out of the circular habit rail and lands on the playfield and cut a section out for the pop bumper area.
Thank you!
Picture of post not fitting in new playfield. Only a portion of the post (the threaded part) is able to make it through the playfield.
