(Topic ID: 210784)
MI Pinball Refinery GI Lighting Rail
By HemiOrange09
1 year ago
  • 71 posts
  • 31 Pinsiders participating
  • Latest reply 1 year ago by TigerLaw
  • Topic is favorited by 25 Pinsiders
    There have been 18 images uploaded to this topic. (View topic image gallery).
    This topic is closed.
    There are 71 posts in this topic. You are on page 2 of 2.
    #51 1 year ago
    Quoted from oyvindmo:
    Having taken a closer look, I'm starting to wonder if cabinet mounted lighting is a no-go on Safecracker. At least on mine, there is really no_ clearance between the ramp assembly and the cabinet on the right side. While lifting, it's possible to wiggle right-to-left a bit, but the total clearance (left+right) is only about 1/8". Are the magnet strips thin enough that it will work?
    Anyway, a suitable length would be 25-26".
    The mounting magnetic strips are thin just under a 1/16" thick per each side, so it would be close. It's up to you, but I can make them shorter for your Safecracker without a problem.
    As for where the bracket is located on the ramp, just don't attach the magnet strip to the cabinet in that location so it won't interfere with it.
    Just let me know,
    Steve
    MI Pinball Refinery
    #52 1 year ago
    Playfield should have a gap on either side from the cabinet. If it's rubbing or up against the side of the cabinet, your cabinet is not square due to being on an uneven surface, uneven legs, cabinet damage or the playfield mounts are worn. Otherwise you would have to just pull the strip off its magnetic mount and either disconnect the plug or let the lights hang over the side of the cabinet.
    #54 1 year ago
    Order placed. Will update this thread once I have (hopefully) installed them in my Safecracker
    #55 1 year ago
    Orders will be shipping out tomorrow or Monday at the latest .... Thanks to everyone that placed any order with me, I will post more pictures of machines that I will be adding these to...
    If anyone has any questions, just let me know.
    Thanks,
    Steve
    MI Pinball Refinery
    #56 1 year ago
    Quoted from HemiOrange09:
    Yes, are you going to sell them with that fader that was posted above? One stop shopping and one shipping cost. That's what it really needs.
    #57 1 year ago
    Quoted from MustangPaul:
    Yes.... This has been requested and I can / will be adding a "low tech" fader controller as an optional upgrade for this mod. This will be an "optional upgrade" for the base lighting rails, so if you just want the rails without all of the Hi-Tech toys you can get it.
    #58 1 year ago
    Yes.... This has been requested and I can / will be adding a "low tech" fader controller as an optional upgrade for this mod. Also I am testing a high tech smart phone / I-phone Wi-Fi RGB controller as well.... These all will be an "optional upgrade" for the base lighting rails, so if you just want the rails without all of the Hi-Tech toys you can get it.
    That would be great, I have a dumb phone so I'd go the low tech route. I also wouldn't need the power connector on the end cuz I have an 12v, 8 way power splitter drawing power from the service outlet via a 3 amp wall wart in my games for mods.
    #59 1 year ago
    No problem. I can make you this mod with the "low tech" dimmer control option with straight wires (no connector) to connect to your power source. How long do you need the harness?...
    I'll have these dimmers in stock in about a week. I will be adding these options to my website today if you would like to place an order.
    Thanks,
    Steve
    MI Pinball Refinery
    #60 1 year ago
    Thanks,
    Steve
    MI Pinball Refinery
    My splitters are on the right side of the cabinet just a little forward of the cab speaker so I'm thinking 3 feet maybe. Is the original connector a Molex 3 pin female? The splitters are male connectors.
    #61 1 year ago
    I am definitely a fan of the pinstadium. However I have been buying lighting from Steve for many years. And I had to order a set of these check them out. Looking forward to them coming in and putting them in my Metallica.
    #62 1 year ago
    EDIT......Yes I can do a 3 pin male molex connector, no problem... I seen you pictures and post on the other thread.... Just order them and I will build them for you.
    #63 1 year ago
    Here's some pictures of Pin15 machines with my rail lighting kits fully installed in his machines. You can see the harnesses are routed and hidden in the rear of the playfield.
    Rob Zombie and Scared Stiff have VU LED lighting turned on.... The boney beast sure comes alive ...
    Steve
    MI Pinball Refinery
    #64 1 year ago
    The others have just the white lighting rails intalled in them....
    Star Trek Pro
    Ghostbusters Pro
    Aerosmith Pro
    Ironman
    These are available to order on my website ....
    Thanks,
    Steve
    MI Pinball Refinery
    #65 1 year ago
    Here's a few pictures of my lighting rails in my personal Refinery Edition Star Wars Premium. The first one is with the lighting off and the others are with it on... I have a color controller in my personal machine to change the colors.
    My lighting rail kits do not include the speaker lights...
    Steve
    MI Pinball Refinery
    #66 1 year ago
    Great work Steve. Thanks again for coming out and helping me get these awesome rails installed in my games.
    One quick note for potential customers. The pictures of my games make the playfield look little more washed out then it is in reality. I’m very careful to avoid that. I like to try keep the colors as true as possible. Again it’s typical case where pictures don’t do it true justice.
    Also I can see why a dimmer on some games would be nice to get that perfect lighting effect.
    #67 1 year ago
    Quoted from pin15:
    Not to nitpick but the 3rd picture doesn't look right, the area to the right of the lcd on the pf still looks as dark as stock.
    #68 1 year ago
    I’m probably wrong but I believe that’s cause this is one of Steve’s Custom systems with blacked out ramps and wire forms ?
    #69 1 year ago
    Quoted from Yelobird:
    Hmmmmmmm.
    #70 1 year ago
    The first round of orders have shipped out. I'm working on them as they come it.
    Here's a few pictures of a Refinery Edition SMVE with the lighting rails with a RGB controller.
    1st one is them off and the others are different colors selected
    Thanks,
    Steve
    MI Pinball Refinery
    $ 999.00
    $ 245.95
    Allteksystems
    $ 12.99
    Medisinyl Mods
    $ 400.00
    Great American Pinball
    $ 6.00
    PinWorlds
    $ 8,500.00
    Hobbit Black Arrow Out of stock
    Operation Pinball
    $ 134.95
    Hookedonpinball.com
    $ 69.95
    $ 42.00
    The MOD Couple
    Pinball Stuff
    $ 48.00
    $ 38.00
    $ 131.00
    Cabinet Parts
    Tilted Pinball
    Lighting - Under Cabinet
    $ 14.95
    $ 99.99
    $ 999.00
    $ 99.00
    Docquest Pinball Mods
    $ 9,000.00
    Operation Pinball
    $ 69.00
    Id Rather Play Pinball
    $ 40.00
    $ 154.00
