(Topic ID: 343690)
New machine owner here! What else do I need?!
By the_lowering
10 months ago
#1 10 months ago
Hello everyone,
I just bought my first machine (stern bond premium) and I can't wait for it to arrive! While I'm waiting for it, I'm wondering what else do I need to protect this baby?! I made a similar post on Facebook and so far I've been told to buy:
* Mylar/Shooting lane protector
* A Jetpack pin alignment corrector
* Bond girl loop plastic
* Mirror blades (for aesthetics?)
Is there anything else that I might need? Do I need all of these that were suggested to me?
Thanks in advance,
Tye
#2 10 months ago
Wax it up all purty before you play and maybe about every 100-150 plays and clean the rubbers up a little when you do that
#3 10 months ago
Hello back.
Congratulations on your first of many games.
Welcome to the fun. Post here if you have questions or need help.
#4 10 months ago
New balls to replace the ones coming from Stern
#5 10 months ago
Yup, throw the balls that come with the game straight into the garbage. Get some Novus 2 and CP100 for playfield cleaning. CP100 is great for cleaning rubbers as well. I'd suggest a soldering iron and a small roll of solder as youll have to resolder wires every once in a while. A basic set of tools like screwdrivers, nut drivers, etc will come in handy. I also change the flipper coil stop screws from the factory 5/16" head to allen head cap screws, as we have problems with the heads breaking on our route games. Likely not a problem in a home environment but figured I'd mention it. From the items you listed those are all good except for the mirror blades which are just aesthetics.
#6 10 months ago
Quoted from the_lowering:
You'll never notice them whilst playing so what's the point. Put monies where they belong, in needed tools and pin #2 fund
#7 10 months ago
You'll find that here: https://pinside.com/pinball/market/shops/1492-the-electric-playground-/09064-bond-girl-upper-loop-fix-aka-bond-loop-lid
You'll find that here: https://pinside.com/pinball/market/shops/1282-rocket-city-pinball/08874-jetpack-pin-alignment-corrector-james-bond-007
I do have one other item designed to correct a Stern design flaw, the Multiplier Light Corrector. While it's not necessarily for 'protecting this baby', it does resolve an issue you can't un-see. It's found here: https://pinside.com/pinball/market/shops/1282-rocket-city-pinball/08777-multiplier-light-corrector-mod-james-bond-007
If you decide to dive into the cosmetic stuff, there are dozens of mods out there (including several of my own and many from several other excellent modders), you can peruse them all here: https://pinside.com/pinball/market/shops?gameid=3058
Congrats on the new game!
#9 10 months ago
Quoted from TheLaw:
I agree. Only mod out games you never plan on selling. Which will not be your first one for sure.
#10 10 months ago
Quoted from Wylte:
okay! Where is a good place to buy replacement balls? and just out of curiosity, what is the difference in the one's that are included?
#11 10 months ago
The included balls either are not the highest quality, or at times are not the highest quality; better to just replace them.
Plenty of places to get balls. The rule is the super shiny ones don't work well in games with magnets, they get magnetized and screw things up. Magnets need a carbon ball usually.
Titan, Ball baron, pinball life etc
#12 10 months ago
I bought some on pinside from no gouge, but there are plenty of sellers. The problem with the stern ones is the coating will literally flake off after few plays. Gets your playfield dirtier faster and the balls look like shit quickly.
#13 10 months ago
Play your game for 30 days then come back and ask what you can buy/need.
#14 10 months ago
Another game
#15 10 months ago
Throw away your old furniture and buy more pins.
#16 10 months ago
Deeper pockets ... there never is just one !
Congratulations..
Hope it comes soon
#17 10 months ago
Don't buy stuff just because you're excited to own a pinball machine. Complete waste of money.
It's fun for a bit but in my opinion you don't even need to wax the playfield.
The shooter lane protectors are a wise move though.
#18 10 months ago
They breed like rabbits.
I wake up and there is a new pin in my garage.
It's crazy! The addiction real.
-1
#19 10 months ago
Shaker Motor.
It's not that difficult to install yourself, I recommend getting the actual STERN shaker motor, though pinball life sells a perfectly fine replacement.
You'll be surprised the difference a shaker motor makes.
The next upgrade is anti-reflective glass. $250.00, but it makes quite a difference.
The cheaper than anti-reflective glass is to change adjustment 'Game play backbox brightness' to 5% instead of 100%. This is way at the end of the SPI adjustments (go backwards in the menu to find it). This makes the backbox dim down during gameplay and helps quite a bit with reflections on the glass.
I do like mirror blades...
Your slingshots, straight from the factory are usually VERY VERY active. Use a nut driver, take off the bottom nut on your slingshot plastic. Loosen the top nut (different sized nut driver). Rotate the slingshot plastic so that you can see clearly the leaf switches that activate the slingshot.
This gap should be NO LESS than the thickness of two dimes, the gap should be a bit more than 1/16 of an inch and less than 1/8 of an inch. You'll find these contacts very close together. I use a small flat bladed screwdriver, and shove it between the points. I gently bend the leaf switches apart. Then I usually have to bend them back together to get the right gap. This can take a couple of attempts to get 'dialed in'.
When the slingshots are very sensitive, you can't get control of the ball easily. Making them a bit more 'dead' helps with your high scores quite a bit.
You can test the sensitivity with the plastics still rotated out. A ball that gently rolls down the length of the sling shot should no longer activate, but when the ball hits the slingshot rubber with a bit of force the slingshot should still be active.
When you get it right, reassemble and tighten down the nuts.
#20 10 months ago
Quoted from Chambahz:
I like smoking crack as well.
€ 80.00
Pino Pinball Mods Shop
€ 90.00
€ 80.00
$ 6,999.00
The Pinball Place
$ 185.00
Sparky Pinball
€ 23.00
Pin-Decals
$ 50.00
Duke Pinball
$ 385.00
Avid Creations Wireforms
$ 120.00
Duke Pinball
$ 425.00
CRCades
arcade-cabinets.com
King George, VA
$ 85.00
ChainsawMods
Playfield - Plastics
HurryUpPinball
9,000 (OBO)
Middletown, DE
$ 59.99
Print2pin
€ 12.00
Pin-Decals
9,299
arcade-cabinets.com
$ 19.99
FlipMods
Gameroom Mods
$ 19.99
FlipMods
$ 154.00
9,499
Wood Dale, IL
Great pinball charity
Pinball Edu
