Quoted from crujones4life:I have someone looking for LED displays for their 8 ball. They currently have only 1 failing (player 1). My question is can you replace only 1? Or do all 4 - 7digit and 1 - 6 digit displays need to be replaced together? Never owned an early solid state Bally. Does it have a control board that needs replaced like early Williams?
When replacing just plug and play?
Where can I find the best deal whether I only need 1 display or all 4/5? Links would be awesome! Thanks!
There's no technical reason why you can't mix and match. However, the appearance may differ a bit between the LED and original plasma displays.
As long as the plasma display isn't seriously burnt up, the PCB can usually be repaired for a few dollars of electronics components.
A section on display repair: https://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Display_problems
Sometimes, individuals/suppliers also sell repaired plasma displays.
Yes, you can sometimes buy individual LED displays or a full set of them. However, I just did a quick check on a couple brands, and currently, I'm not really seeing individual LED displays for sale--just mostly full sets.
Pinitech, wolffpac, pinscore, and xpin are brands that are currently available. It looks like pinitech and wolffpac are only offering DIY kits (meaning, you solder everything together yourself, rather than buy a plug & play ready display).
