Quoted from proco:Am I satisfied with my prediction image? Not really.
Did I spend 2 hours rebuilding it in future pinball? Oh absolutely.
Comments on the third image:
A - Probably a magnet.
B - Either this is to feed cables or another hole or kicker, but then I have no idea how that would be fed, maybe with a diverter.
C - There must be something else there because currently this looks ridicolus.
D - I think there will be some sort of diverter to either get the ball into the hole or VUK with the two lamps next to it, or to shoot though the bumpers.
E - I'm not sure if the leftmost hole is an insert or a real hole. Because if it's in insert it would be in the line between the two rubber posts which makes it look weird. If it's just a hole it might be reasonable to assume there is a rubber connecting the posts.
F - Along with E, big questionmarks on what that area is supposed to be.
G - Not sure what the two holes behind the scoop are supposed to do.
H - If there is a post the loop would be very tight but lines up better with the inserts, but also has a very weird bend. So I think there is no post and instead the metal guide ends right next to the target.
I - Unusual hole there, looks like it belongs to a drop target.
J - These are ALL small LEDs similar to Wonka. They are probably a crowd in the artwork and during gameplay they will flash so it looks like they are all taking pictures.
L - It's Eric so I assume you can somehow save the ball there.
K - Tilt warning inserts.
Well this is just fucking impressive.
