Hi everyone,
First post on here as I am now the proud owner of my first pinball machine, Judge Dredd, but I am having a bit of a problem.
The machine was thick with dust so I stripped it down and cleaned everything up (see the before and after pictures). I was very surprised to find that when I put everything back together it worked first time with no errors on start up and from what I could see everything working.
I played about 7 short games and during this time had a few power offs where the machine totally powered off for a few seconds and then switched itself back on and started working. There didn't seem to be a pattern to this, it could be at the start of a game or a few minutes in and not when anything in particular happened in the game.
I noticed that the left top flipper was getting stuck under the metal rail so I switched the machine off removed the glass to add an extra washer on the posts holding the rail up to make sure it cleared the flipper.
After putting the glass back on the machine won't start up anymore. None of the play field or back glass lights come on and nothing on the play field moves or works. There is no sound although some slight static for the speakers. The only thing that appears to have power going to it is the dmd which shows a garbled mess of dots (see picture)
Behind the back glass the 3 lights on the CPU board D19, D20 and D21 don't light up at all. I think 2 of the lights that should be lit on the power board are also off. I will find out which these are and update later today.
As this is my first machine I'm not quite sure where to start with diagnosing the fault. Could this all be caused by a blown fuse? If so does anyone have a suggestion of which are most likely to be the cause or should I just test them all? Or is this going to be a bigger problem than just a fuse?
Any help would be greatly appreciated as I still haven't played a proper game on it yet.
Thank you
Liam
