Quoted from buffaloatx:Had this problem as well, you need to adjust the switch... Unfortunately you need to remove the entire assembly to get to the switch.
I had 4 Switches not working straight out of the box that neded adjusting, but at least mine had 1.03 installed and booted right up first time.
New code is fun, 95 mil, with out KISS army...
Which switches? For mine it was the scoop, spinner and I might need to look at the saucer. I had to laugh at a facebook post by Jared which said all games are tested before shipping. Yes, they are tested, but they are not thoroughly tested enough. These (and other) issues are not the result of shipping, but assembly tolerances being out just a slight amount.
Removing the assembly is straightforward and easy. Instead of bending the arm, all it might need is to loosen the 2 switch screws and then change the angle of the switch body a little. It seems to have room to move a bit.
Mine came with 1.03 as well. I was playing tonight and noticed some weird stutters in the game that seemed to affect everything from sound to lighting. It only happened a few times though.
Rob
