hi all, just thought i would start a thread on another experiment i have finally begun based on lessons learned from
my carelessness with my c37 playfield
since a laser cut vinyl decal process i worked on turned out so well for the c37 'fix' i have been meaning to try some similar 'decals' and application to a couple of my other games
although my strange world was home use only and in really really nice shape - the center of playfield at the inserts had begun to wear, with bare wood just at ball kickout and some pretty grimy ball swirls around the grid of numbered inserts
i want to try and apply another 'non permanent' vinyl decal, laser cut, over the whole area - to keep any further wear from occurring and as a challenge to see if i can do it well enough to pretty the game up even more, with out the perils of my good old magic eraser and rubbing alcohol!!!
if others are interested i can eventually post a more detailed 'play by play' ... but just sharing progress after some hours of work today on it
i took a digital photo over the playfield, brought it in to adobe illustrator and began work on a new vector art file to eventually pass on to my printer for the laser cut vinyl decals
i repeatedly print to my laser printer on clear sheets which i can overlay onto the playfield, mark up etc, then go back and adjust the art file so it is a near 'exact' match to the area being worked on
no laughing please .. i know the art file looks simple enough, but about 4 hrs and 10 overlays so far ... i am a bit of a 'perfectionist' and don't let all the geometry fool you - lots to line up!!
at any rate its all good now except the final sizing and tweaking of the insert circle positions so that when laser cut from the final decal, the inserts below register how i want them too
here's a few shots - i'm glad to have finally gotten this going, with the bulk of the effort now done
shot of playfield .. not bad but you can see the ball wear at kick out hole and some of the grime around the center inserts
just a shot of some of the print outs!
and a shot of a 'mock up' easier to see than the clear prints
... so next to line up the inserts cut outs, then some color matching and getting the file off to the printer
more to come, lets hope it works out !!
cheers, Ron
