(Topic ID: 220905)
New 6 inch speakers found
By KenLayton
5 years ago
  • 113 posts
  • 50 Pinsiders participating
  • Latest reply 2 years ago by TheLaw
  • Topic is favorited by 79 Pinsiders
    There are 113 posts in this topic. You are on page 1 of 3.
    27
    #1 5 years ago
    For those with early solid state games from Williams, Gottlieb, and Bally which use a 6 inch full range speaker, they have been hard to find at times. I've found an excellent replacement at Newark (formerly MCM Electronics).
    http://www.newark.com/mcm-audio-select/55-5690/6-5-full-range-dual-cone-speaker/dp/95Y2940?ost=55-5690&scope=partnumberlookahead&exaMfpn=true&searchref=searchlookahead&ddkey=http%3Aen-US%2FElement14_US%2Fw%2Fsearch
    It's 6.5 inches but the mounting holes all line up with 6 inch original speakers. This is full range, 8 ohms @ 50 watts. I just put one in an Eight Ball Deluxe and it fit & worked perfectly. So crisp and clear is the sound now. We just bought a dozen of them because the price was so good. Each speaker was individually boxed too. We paid about $6 per speaker.
    Newark # 95Y2940 or MCM # 55-5690.
    #2 5 years ago
    Have you found any good replacement speakers for the stern pro model speakers?
    #3 5 years ago
    Quoted from SDAmusements:
    Have you found any good replacement speakers for the Stern pro model speakers?
    No, I haven't really looked for modern Stern machine speaker replacements. Most people were simply buying Pinball Pro or Flipper Fidelity upgrade speaker kits.
    The specs I've seen for Stern "pro" speakers are these:
    Cabinet floor speaker: 8 inch, round, woofer, 4 ohms, 25 watts
    Backbox speakers (both are the same): 4 inch, square, midrange, shielded magnet, 8 ohms, 10 watts
    My buddy Welby Bergum and I have been doing so many older Williams, Gottlieb, and Bally solid states lately. I'm seeing more and more coming in with bad speakers (rotted, corroded, blown, or dead). Had an Addams Family come in 3 weeks ago which had virtually nothing left of the paper cone in the cabinet floor speaker. Those MCM/Newark 6 inch speakers are a godsend and at such a reasonable price too.
    #4 5 years ago
    Do they have an 8" you have found works, Ken?
    #5 5 years ago
    Quoted from KenLayton:
    Thank you sir! Just ordered 6. Had to replace a missing one in Data East and ended up slapping a Stern modern one in as a placeholder
    #6 5 years ago
    If you're talking about an 8 inch woofer for the cabinet bottom in a Stern Pro, check out these two speakers:
    http://www.newark.com/mcm-audio-select/55-3231/70w-rms-4-ohm-rubber-surround/dp/43W7872
    http://www.newark.com/mcm-audio-select/55-3210/100w-rms-4-ohm-paper-cone-woofer/dp/43W7867?st=8%20inch%20speaker
    And check out those prices, very reasonable.
    One is rated at 70 watts and the other at 100 watts. They aren't gonna blow!
    Those were from just taking a quick look on Newark's website. I have not actually tried those 8 inch ones.
    #7 5 years ago
    Quoted from MT45:
    Had to replace a missing one in Data East and ended up slapping a Stern modern one in as a placeholder.
    I forgot about Data East. Never paid much attention to the speakers they had. Guess I'll have to check out the next one that comes in for repair or restoration here.
    Game Plan might use the same speaker too.
    #8 5 years ago
    Quoted from MT45:
    You ought to receive them quick. Newark is in South Carolina and ships speakers via UPS. We got ours in a week since we are in Washington state.
    #9 5 years ago
    Thanks for the notice. They looked good so trying 10 of them.
    #10 5 years ago
    Wondering if these will work in a Sinbad?
    #11 5 years ago
    Quoted from Gryszzz:
    Yes, it should.
    #12 5 years ago
    Thanks - I ordered a few of these.
    #13 5 years ago
    Picked up a Bunch too! Thanks!
    #14 5 years ago
    Just to add to this thread, if anyone with a Bally classic with the volume control mounted on the coin door, here is the correct volume control for you:
    https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&freeText=140514&langId=-1&storeId=10001&productId=140514&krypto=jnhODawy5%2Frl%2Ff63cm3HsfgdnTUpjE2armGD8g1oT3G12sxv0QS5GjyMxoLNTTys5cAP765sw6fT8ZXqORrVytXVGtZyQSJ%2Fg7DxMjY3kDc%3D&ddkey=https%3AStoreCatalogDrillDownView
    Jameco Electronics # 140514 just $3.95 each. Time to replace those old "scratchy" or fluctuating ones.
    This also works on classic Stern solid states.
    #15 5 years ago
    thanks for the links! Will have to keep this thread in my back pocket for when I'm needing these!
    #16 5 years ago
    killer, now somebody fine me some good stern replacements!
    #17 5 years ago
    Quoted from ccbiggsoo7:
    Modern Stern?
    Kicker 41DSC44
    Pyle PLPW8D
    #18 5 years ago
    I received my speakers today, and found exceptional Quality for $6.00 a speaker!
    Thanks Again!
    #19 5 years ago
    Just put one in my Centaur project and the sounds is great (I can now appreciate the reverb)
    Quoted from spidey:
    Modern Stern?
    Kicker 41DSC44
    Pyle PLPW8D
    I have a PLPW8D laying around from an arcade project it wouldn't fit into. I will have to try it out also. Glad I found this thread.
    #20 5 years ago
    I just put one into a Stern Orbiter 1 machine. It's a bit tricky getting it to fit because of the unusual mounting place in the neck of the machine. I'll try to get pictures later today. It does fit perfectly on the speaker mounting board, but you need to use 3 inch long screws to mount the whole works back in the machine.
    Orbiter 1 new speaker installed (resized).JPGOrbiter 1 new speaker installed (resized).JPGOrbiter 1 old new speakers (resized).JPGOrbiter 1 old new speakers (resized).JPGOrbiter new speak (resized).JPGOrbiter new speak (resized).JPG
    #21 5 years ago
    Ken, I have quite a few Gottlieb, Bally and Williams early SS pins. The speakers all appear to be original and work. Is it worth $6.00 to replace these speakers in your opinion? Is the fidelity and clarity a little better or a lot better? I like to keep original parts on my restorations, but good sound is important enough to spend a few bucks on if they are noticeably better.
    Mr. Layton, I want you to know that you are one of my favorite posters. You are knowledgeable and always willing to share your expertise here on Pinside. If it is a KenLayton post, then I know that it will be worthwhile!
    #22 5 years ago
    The Eight Ball Deluxe and the Stern Orbiter 1 I just put these speakers in sure sound alot better and crisper! Great for games with speech.
    #23 5 years ago
    Quoted from OLDPINGUY:
    Thanks Again!
    They sure sound better than the wimpy original speakers.
    #24 5 years ago
    How much are you guys paying for shipping?
    #25 5 years ago
    I think for the dozen we bought was about $25 on UPS. US Mail would have been about $45.
    #26 5 years ago
    Thanks. I put 10 in my cart and cheapest shipping was $45. Must be more expensive to CA.
    #27 5 years ago
    Quoted from Pecos:
    I second this motion...
    #28 5 years ago
    Quoted from Jvspin:
    The cost of shipping 10 to WI is $24.72
    Will have to get a few of these soon! They look mighty hefty compared to the stock units.
    #29 5 years ago
    Any other speaker sizes/games in this value to share?
    Backbox speakers that rock as well?
    #30 5 years ago
    I just ordered six. Shipping to Tucson, AZ was $24.49. Check all shipping option pricing. The USPS priority mail was cheaper than the 3-5 day ground shipping.
    I am only going to replace the talkers and pins with more sophisticated sounds. I will not be replacing the speakers in Future Spa , Harlem Globetrotters On Tour and Phoenix. I doubt the speaker will add much to the simple bleeps and bloops of the really early SS games.
    Thanks Ken!
    1 month later
    #31 5 years ago
    Ken, thanks a ton for posting this info. Just used one of these to replace a damaged speaker in a Jungle Lord and it was a perfect drop-in replacement.
    Cheers!
    2 months later
    #32 5 years ago
    I have one in my Meteor and while the original wasn't blown, I put one of these in there anyway since I had to order one for my Stargazer build. It sounds soooo much fuller. Well worth the few $$.
    #33 5 years ago
    Just got my order yesterday, while my current project doesn't have speech, this is a much nicer looking speaker than what was in it.
    #34 5 years ago
    Just recieved mine as well ... they also work in WPC cabs
    #35 5 years ago
    Quoted from Stretch7:
    was it a big improvement in sound over wpc stock speakers?
    #36 5 years ago
    How did it sound in a WPC cabinet?
    3 weeks later
    #37 5 years ago
    Just picked up a 1980 Gottlieb Panthera. My 1st non-EM. Will these fit in backbox? Someone stuff a car speaker behind the mounting bracket
    Update - it fits.
    #38 5 years ago
    Thanks for sharing the link!!! I just ordered 6 $20 for 3-5 day shipping to Canada! Can't wait to install these!
    #39 5 years ago
    Great deal
    4 weeks later
    #40 5 years ago
    Quoted from jimmyb:
    Did you receive them yet?
    #41 5 years ago
    Have to say, these work as advertised. Dropped one in an Eight Ball Deluxe and a Meteor. Couldn't have been simpler. The sound quality is improved, but not dramatic. Also, I ordered 4 speakers to get the price break and one was bad (no bass). At $6, it's not worth returning, but just a heads up.
    If you need a replacement speaker, don't hesitate!
    #42 5 years ago
    Daughter: DAD!! huge box at the door!! What you get?
    Me: WTF ? What can be in that box?
    Daughter : Can i open it?
    Bought a set for my machines. I have yet to install them, but this is how they were shipped less the brown packing paper I already removed.
    #44 5 years ago
    Quoted from wolffcub:
    So that is how they justify their shipping cost!
    #45 5 years ago
    Thanks Ken for the lead, just ordered a box of these myself !
    #46 5 years ago
    Just checked their stock. As of today, there is only 16 left. Next shipment is due on June 17, 2019. I'd say if you guys need any now, you'd best get them ordered now or else wait until June 17th.
    #47 5 years ago
    Thanks for the tip KenLayton! I ordered 4 and am expecting Time Warp to sound better than 1979.
    The other 3 are for future pins.
    1 month later
    #48 5 years ago
    Now "Out of Stock" until the middle of June.
    6 months later
    #49 4 years ago
    This speaker model is now listed on the Newark website as "no longer available". Any other recommendations either at Newark or elsewhere?
    This page was printed from https://pinside.com/pinball/forum/topic/new-6-inch-speakers-found/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
