The Machine - 1978 Gottlieb Close Encounters of the Third Kind
Machine History:
I received this machine as a housewarming gift from my Father-In-Law back in August. He used to repair machines for a family member who collected EM machines, and still owns a couple himself. According to him, he had it 'almost working' and then just never finished it after that collector family member passed away. I don't know the history any further back than that. However, I am lucky enough to have a schematic for it!
General Condition:\
Everything seems to be in pretty good condition. We actually got it up and mostly running on the day he dropped it off. There's a bit of grime around the bottom of some of the posts on the score wheel, and some switches have needed burnishing.
Service So Far:
I've replaced most of the bulbs, cleaned the playfield, and replaced the rubber.
As mentioned before, I've cleaned some switches when I noticed they were particularly bad.
I did some adjustment of the Ax/Bx relays and they seem to be working well.
I've cleaned a set of score reels that were sluggish, and they seem to be happy. I plan on doing more as time permits.
The Solid State sound board doesn't work, and the speaker is dry-rotted. I'll replace the speaker after replacing the caps on the sound board... I'm saving that for last as it should be easy, and I want to get the hard stuff out of the way.
This is my first pinball machine. For work, I design custom electronics and install AV equipment, so I can solder, use a multimeter, etc. I've been reading carefully a lot before I approach anything (thanks PinRepair.com and HomePinballRepair.com, plus this site!). I've bought burnishing strips and a couple switch adjustment tools to make things easier.
The Problem:
There is something going on with the "Subtract Bonus" circuit. The cam wheel always increments correctly when a bonus is added. During the startup, the solenoid fires well, and resets it...mostly. Sometimes, it doesn't quite get all the way to 0, particularlly if it was really high, like over 10 steps. I haven't delved too deep into that problem yet, but it does eventually fully reset if I trip the start sequence again.
There is a bigger issue to me at the moment, and it may be related. After a ball falls out of play and hits the switch at the very bottom of the table, the game starts awarding bonus points... and never stops. You just keep getting 1000 points forever. This is because the cam wheel isn't subtracting every time the points are awarded, so it isn't hitting the zero-switch, ending this loop.
Attempts thus far:
From what I can tell, the movement during this is portion is controlled by two switches. One is on the K relay, and one is Score Motor 4D. The solder joints look good, and the connection rings through nicely. I've tried adjusting them one way or the other, and its sometimes feels like I am getting close. Sometimes, it is as if the contacts are just barely out of time, and the subtract bonus solenoid seems to jerk, but not quite strong enough to actually move the wheel. If I adjust the switches to be just *barely* seperated, with a barely visible gap, the subtract bonus solenoid will fire when it should, but sometimes double-fires and skips awarding points. I know that small adjustments can be critical for these machines, but this seems wildly difficult to get right, and I think I must be missing something somewhere.
There was a bit where I wondered if the score motor might be turning too slow or fast, causing timing issues. From what I've been able to tell though, it seems in the neighborhood of 26 RPM, which is nominally correct.
I've used alcohol to clean the shafts of the solenoids of the bonus cam wheel. They move easily by hand. An ohmmeter shows ~4.6 ohms of resistance, which isn't far off from the nominal 4.5. The wheel itself moves cleanly and doesn't seem to have any old grease or anything that could be gunking it up.
I've attached photos showing the current spacing of the K relay and the Motor Switch. At this state, I'm not really getting any action out of the cam wheel.
I've also attached photos of the cam wheel itself, and of the schematic. Ignore the circled spot in pencil - its from a previous owner.
IMG_2368 (resized).jpgIMG_2667 (resized).jpgIMG_2669 (resized).jpgIMG_2665 (resized).jpgIMG_2666 (resized).jpg
