Does anyone have experience installing the aftermarket neon transformer used in the SWE I light saber or CV neon ramp?
I have Cirqus Voltaire (CV) and the neon stopped working. I read about the normal causes, ran the flasher test with no luck and also have 10V under test at the connector to the transformer. I have tried unregulated 12V and external battery to the neon transformer without illumination. I even tried a NOS driver board to rule out a bad U3 chip etc and no luck. I have found the appropriate aftermarket transformer, my question is since it is not a direct plug and play installation are there any concerns or wrong way to cut the wires, insulate the connections etc since the output from that transformer to the neon tube is 1500volts.
Any advice is appreciated:.)
