Neon Signs Club- Show us your glow!
(Topic ID: 90412)
By PEN
  • 577 posts
  • 170 Pinsiders participating
  • Latest reply 2 days ago by Rdoyle1978
  • Topic is favorited by 67 Pinsiders
    There have been 526 images uploaded to this topic. (View topic image gallery).
    There are 578 posts in this topic. You are on page 11 of 12.
    #501 10 months ago
    Quoted from RobertWinter:
    3kv seems rather small, even though KingBW has that on his sign. You would need a minimum 6kv transformer for 10 feet of 10mm tube (assuming that's the size of your sign). 7.5kv would give you some headroom.
    Since you already have multiple transformers, I would suggest splitting the sign.
    This weekend, I was thinking of separating the ghosts from the pacman words and trying something like that with 2 transformers. I may also go back and try cleaning off the leads coming out of tube as the copper seemed a little dark like a little oxidation (or maybe from heat). Thinking a lite fiberglass brush or something gently.
    Thanks for the extra input.
    #502 10 months ago
    My newest
    #503 10 months ago
    Neons are great and I love em
    Had many over the years including a couple 6+ footers
    You need high ceilings to hang them properly and out of the reach of people whether touching or falling into them
    Had someone knock over a 6 footer miller time
    That took forever to clean up all the glass and the amazing part most of it still worked sighhh
    I had an original one of these years back and sold it for a few hundred
    Picked up a China replacement slightly smaller for 45 bucks free shipping
    Hard to beat that and a classic!
    #504 10 months ago
    #505 10 months ago
    Quoted from pacmanretro:
    Took an extra week before I got back around to working in sign. I got a fiberglass bristle brush and cleaned the copper wires off tubes. Hard to capture in pics, but shined up nicely....didnt make much difference in performance. Before and after cleaning.
    #506 10 months ago
    Sooo....replacing with single new 3KV 30mA supply lit whole unit but dim in some spots and touching tube with finger would cause a ghost to turn off. Also, "M" in pacman was dim. Hooking same new supply to only ghost half lit them better and no longer would a ghost go out, but first ghost is kind of bubbly inside (I don't know the term, but I am sure you know what I mean-like you can see it flowing/dancing a bit). Cleaning wire leads didnt do anything noticeable.
    I left new supply on only the ghosts and added a second 3KV 30mA supply to run "pacman".
    Final result...same little chase looking effect in first ghost, and same dim middle of "M" in pacman. Been on 20 min and no change.
    However, didn't get worse and still looks pretty good; so, while not quite perfect, compaired to dead....I'll call it a win!
    It's honestly probably a little old/worn/outgassed...like I said, I got it used and have no idea it's age or useage hours.
    Thanks again for the help guys!
    Time to put some shades on and stare at the beautiful glow!
    #507 10 months ago
    The "dim" in the M appears to be burn and there is nothing you can do about that and it will get worse over time! These cheap Chinese neon signs shouldn't need two power supplies to run it as the tubes they use are small in diameter then commercial neon signs!
    If you haven't already, take all of the rubber boots off the leads and make sure the leads (the wires you cleaned) are making solid contact! Cleaning the leads is great but more than likely isnt your issue! These leads typically have paint on them and this is common as the leads get paint on them when the tubes are dipped in paint!
    One other thing to check is ..... is there a ground wire? If so, make sure it's making good contact with the frame!
    #508 10 months ago
    Quoted from meSz:
    Thanks. I figured both the one ghost and the "M" were just wear at this point toi. No ground wire. I cleaned and twisted tight only the ends with leads I was working on, but did NOT check any of the ones going from tube to tube. And you are right, one of the leads I worked on did have a lot of black paint crap all over it; got off what I could and made sure wire was on good bare spot as best I could.
    I will clean and check the other's as well now.
    #509 10 months ago
    My glow game has been off for a while, but I brought it back for Christmas.
    I am a huge Warriors fan!
    #510 10 months ago
    Quoted from jorge5240:
    even though I cant stand the warriors (cavs fan) that neon is pretty sweet.
    #511 10 months ago
    #512 10 months ago
    Well I just purchased one of my biggest and coolest neons yet. I will post a pic when it gets to my house in one piece.Keeping fingers crossed.
    #513 10 months ago
    #514 10 months ago
    Is that "Wendover Will"?
    #515 10 months ago
    Here’s mine! Looking to add another, love the glow
    #516 9 months ago
    I have been contemplating having a "Dead Nudes" sign made up... Just to be funny.
    #517 9 months ago
    Quoted from Pugsley:
    Don't do it. That kind of sign tends to attract necrophiliacs.
    #518 9 months ago
    Here are two for you Blitzburgh99.......
    First one is not a neon but an "LED Neon Sign". At least that's what they call it! It's an LED but instead of the typical all plastic frame and all they have it affized to a metal frame just like a neon.
    The second one is a Heineken neon with the Pittsburgh Point and skyline all in neon.
    2 months later
    #519 7 months ago
    I've always wanted this sign... 1950's Hamm's
    #520 7 months ago
    Pacmanretro... the 3kv transformer is still too small for the text which is why the centre is dull. Put a 10kv on the whole sign and youll be OK. Electronic transformers are self adjusting so it will only deliver what the sign requires. In other words, if the sign requires 8KV then a 10KV will output 8. The bubbling in some of your tubes ( namely clear red) is called " jellybeaning". Its the high frequency pulses inside the gas discharge. A good electronic transformer will have "anti jellybeaning" circuitry inside. But if buying the cheapest you can from Ebay is your criteria then learn to love those marching ants. Also smaller diameter tubing has a higher resistance and so takes MORE power than a larger tube, not as suggested before by someone else. Chinese signs are often under gassed to fit the tubing onto a certain transformer and reduce resistance but it leads to failure.
    Plenty of neon shops still in the USA, go ring one and get yourself a decent transformer. I recommend Neon Pro ( Chinese)... Evertron (USA) or Ventex ( USA). Most of the other US manufacturers have moved their production base to China to cut costs but the products have become unreliable and the end result is that they now sell far less than they did.
    Cheers... Retropin
    #521 7 months ago
    Quoted from scampcamp:
    Neat looking sign. It appears the power supply has a sequencer built in so I assume the glasses of beer flash on and off??? Can you take a pic lit up?
    #522 7 months ago
    Quoted from Retropin:
    Cheers... Retropin
    Thank you very much for the extra info Retropin! I had already bought a few of those cheap chinese supplies, but I will certainly be checking out some better ones now.
    Thanks for the voltage explations too
    #523 7 months ago
    I received this Ghostbusters Neon sign as a gift several months ago. Makes an excellent Ghostbusters pin topper.
    #524 7 months ago
    Took some pics tonight.
    Anyone interested in the Boar's Head sign? Its kinda large for my space and I really don't have anything it fits with. Prefer to not ship it, but if you're local to Allentown, let me know if you're interested.
    Chris
    #525 7 months ago
    Quoted from SilverUnicorn:
    Is Boars Head the Deli (lunch) meat??
    Neat looking sign!
    -1
    #526 7 months ago
    Quoted from meSz:
    Neat looking sign!
    Yes sir.
    #527 7 months ago
    Quoted from meSz:
    Neat looking sign!
    There was a kid in my grade school that always smelled like lunch meat
    #528 6 months ago
    Quoted from Blitzburgh99:
    Cool! Would they be interested in a neon sign? LOL
    #529 6 months ago
    Perhaps his parents worked at the Oscar Mayer factory?
    #530 6 months ago
    'what kind of kid smells like Armour hotdogs...'
    Isn't that how it went?
    #531 6 months ago
    Quoted from meSz:
    Mmmm pastrami on rye.
    #532 6 months ago
    How do you spell Williams ????
    #533 6 months ago
    #534 6 months ago
    Quoted from Ballypin:
    Too many L’s.
    #535 6 months ago
    That's for the pps lawyers.
    #536 6 months ago
    LLLLLLLLLLLL O L
    #537 6 months ago
    Not neon but have a chromatic clock and a few pixel pals
    #538 6 months ago
    Quoted from Rdoyle1978:
    LLLLLLLLLLLL O L
    W’llliams
    Like O’Hare or O’Grady
    #539 6 months ago
    Yeah, well......I got nothing. This is why I dont buy Chinese neon any longer.
    (Not that there's anythign wrong with that).
    Chris
    #540 6 months ago
    The first neon the bride gave me the ok to put “in the house!”
    #541 6 months ago
    That's cool! Love the unique ones!
    #542 6 months ago
    Oh, man. I love that one.
    #543 6 months ago
    Anyone ever buy anything from these guys?
    https://www.neonsignsinus.com/
    #544 6 months ago
    Quoted from PAPPYBALL:
    If it's not clear from the website, they are a Chinese company. Not sure what to expect quality-wise. But despite the name, they are not in the US.
    #545 6 months ago
    I have used this company for several:
    http://www.customized-neon-sign.com/
    They work great, price is right, I'd recommend them.
    #546 5 months ago
    Quoted from ramegoom:
    Is everything 139.99? not that that's bad just saying. They have allot of nice signs.
    EDIT:not many are 139.99. I was wondering how some complex signs were so cheap and then you choose the size and they get expensive fast.... I don't like how they did the pricing.
    #547 5 months ago
    Pricing seems to be for the 17 x 14 size. And depending on complexity. Really great price considering you can do it full custom. It's the smaller diameter tubing (abour 5/16") and uses those tiny little 3kv ballasts, but they last well. I've had several of them running 24/7 for the last three years with NO issues.
    Now if your sign requires a larger frame, the price goes up. Still. Great bang for the buck. $139 shipped cannot be beat anywhere in the US.
    #548 5 months ago
    I ordered from a place that I thought was in the US but it's actually in China. The name is very similar to the name a few posts above but it's a different site.
    It's here: https://www.neonsignsus.com/BALLY-PINBALL-GAME-Neon-Sign#.WvNnwC_MzuQ
    Anyway I ordered a Bally logo sign from them about a month ago. The sign took about 3 weeks to arrive. Box was smashed. Sign was broken in about 5 different places. Package was not double boxed so I knew the sign would be broken before I even opened it. There are sending a replacement. Definitely language barrier issue trying to explain that the sign was broken. They wanted me to try turning it on anyway which I reluctantly did. Sign is completely dead. Sign looks to be well made but since I can't light it who knows. I'll see when I get the replacement. Buyer beware if ordering these from overseas. If they are well packed you should be fine. Single boxed, forget it.
    #549 5 months ago
    Quoted from phillyfan64:
    It's here:
    Anyway I ordered a Bally logo sign from them about a month ago. The sign took about 3 weeks to arrive. Box was smashed. Sign was broken in about 5 different places. Package was not double boxed so I knew the sign would be broken before I even opened it. There are sending a replacement. Definitely language barrier issue trying to explain that the sign was broken. They wanted me to try turning it on anyway which I reluctantly did. Sign is completely dead. Sign looks to be well made but since I can't light it who knows. I'll see when I get the replacement. I asked them to double box it but I doubt they will. Buyer beware if ordering these from overseas. If they are well packed you should be fine. Single box, forget it.
    That box looks very familiar - I ordered a Red wings NHL sign from that place or a similar one - was packed extremely well, and worked perfectly out of the box. Hopefully this is just a fluke.
    #550 4 months ago
    My new Modelo neon.
    $ 29.99
    $ 29.99
    Tim's Pinball Mods
    $ 7,299.00
    Flip N Out Pinball
    $ 217.00
    $ 12.50
    $ 22.00
    $ 1,000.00
    $ 60.00
    Mods for your pinballs
    $ 29.99
    $ 39.00
    The MOD Couple
    $ 0.00
    Flip N Out Pinball
    Apparel - Unisex
    ArcadeMade
    $ 24.95
    £ 45.00
    PinballToys
    Flip N Out Pinball
    $ 12.50
    $ 44.99
    Lee's Parts
    Metal-Mods
    $ 6,999.00
    Classic Game Rooms
    $ 40.00
    Lighting - Backbox
    $ 29.99
