(Topic ID: 100099)
Needles in a haystack or Screws/Washers in Walnut Shell media
By wayner
9 years ago
  • 17 posts
  • 11 Pinsiders participating
  • Latest reply 9 years ago by SYS6
    #1 9 years ago
    This is not the biggest problem the world faces but I found retrieving small screws & washers from the media to be cumbersome. The use of a magnetic wand I found works terrific by wiping it through the media and the screws & washers are propelled and cling to the magnet as though their lives depended on it-and it works 100% on my experience.
    #2 9 years ago
    Is that mulch?
    #3 9 years ago
    yeh picked some great mushrooms earlier!!
    #4 9 years ago
    They sell granulated walnut shells at harbor freight, much finer and you can use a regular colander to strain it out with, way easier method
    #5 9 years ago
    I usually dig right in there with my hands.
    Maybe a colander would help you? Just dont use it for pasta anymore.
    That sure is large walnut shell sizing, mine is more of a large ground coffee sizing.
    #6 9 years ago
    Thinking the same thing. ↑
    #7 9 years ago
    I duct taped two hard drive magnets to a dowel. Since they are *very* strong magnets, it's been fairly effective so far.
    I also made a strainer using a soda bottle, cut off the top, and drilled a bunch of 3/16" holes in the bottom. That was the largest size I could use since I had some really tiny nuts and washers in my tumbler at the time.
    #8 9 years ago
    Not sure what pet stores you have down under?
    But something like this is what you seek → http://www.amazingamazon.com.au/desert-blend-walnut-lizards.html
    #9 9 years ago
    Quoted from Blairally:
    ....and what do you estimate the freight cost to Australia would be?? Walnut shell is not commonly available in Australia as apparently it is in the US.
    #10 9 years ago
    Quoted from wayner:
    Whatever shell that "mulch" is - could you perhaps obtain a coffee grinder and grind it yourself? Just a thought.
    #11 9 years ago
    Anyone try using White rice? Results?
    Thats easily available worldwide.
    #12 9 years ago
    Try a pet shop. They often stock it as reptile bedding. Walnut grain or Corn on the Cob grain will do.
    #14 9 years ago
    Good advice wiredoug. Radum is where I actually purchased the course product (the only Australian supplier I am aware of) because fine was not available at the time. I will try them again-thks.
    Quoted from wayout440:
    The ref to 'mulch' was I assume meant to be a funny line from Wolfmarsh-it is 'walnut shell' and it works fine
    (excuse the pun) but I take & appreciate the advice on the desirability of ground shells.
    #15 9 years ago
    I use the magnet wand as well. The thing is a great tool for working on pins and retrieving hardware from media, cabinets, etc...its indispensable.
    I've use reptile bedding with great results. Its finer and works on smaller pieces better.
    http://www.amazon.com/gp/product/B000OQRGF2
    I've used rice as well. It is actually good at holding a polish if using one, but its softer so really only good for finish polishing.
    I used Lymans walnut substitute. It only worked OK and tended to leave the redish dust everywhere.
    #16 9 years ago
    Second hard drive magnets -- very strong.
    #17 9 years ago
    For other Aussies seeking walnut shell, here's where I get mine
    http://www.wellwood.com.au/walshell.htm
    never found any in petshops.
    I also use hard drive magnets for fishing out small bits.
    This page was printed from https://pinside.com/pinball/forum/topic/needles-in-a-haystack-or-screwswashers-in-walnut-shell-media and we tried optimising it for printing. Some page elements may have been deliberately hidden.
