(Topic ID: 254676)
Need to replace my Cirqus Voltaire slingshot switches....
By tamoore
1 year ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by whthrs166
    #1 1 year ago
    The SW-1A-211 switches aren't available from what I can tell.
    Does anyone have a good alternate part to use?
    #2 1 year ago
    In stock in australia: https://www.pinballspareparts.com.au/playfield-parts/switches/pinball-switches/sw-1a-211.html
    But i don't see a reason why any other standup switch wouldn't work in there.
    #3 1 year ago
    Hm they must be standard.
    Any other with other info for these why to be different?
    #4 1 year ago
    Their design is very different because of how the sling is designed. They mount parallel instead of perpendicular.
    #5 1 year ago
    Now I see,their orientation is the same,but mounted directly to slingshot assy,no alone switch with it's plate to the playfield.
    Something like Data East slingshot assy.
    So in theory if you get standard Williams switch with it's "L" metal bracket you can drill it and remove this "L" bracket and you can use it on Cirqus Voltaire?
    #7 1 year ago
    These are what I have in my cart, but I'm not sure they're the proper length. Closest I could find.
    #8 1 year ago
    If they are the correct length.
