The problem I have is the game wasn't always seeing the balls in the batcave. So I started going through the diagnostics and using the pinwiki. When I do the row test check of disconnecting connectors CN8 and CN10 and run a jumper from CN8 to CN10 with a diode I find an issue. From pins 7 and 9 on CN8 and going to pins 3,5 and 6 on CN10 it usually doesn't show a closed switch. Works fine on all the other pins. And I can go from all the other CN8 pins to CN10 3,5 and 6 and get switch closures. So while I see this I'm not sure where the problem lies. The logic probe tells me all these pins on CN8 have pulses, and CN10 has highs. I would appreciate a little help here.
