(Topic ID: 224733)
Need some tech help (Step Unit and Score Reel)
By PatrickATX
7 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 months ago by Tuukka
#1 7 months ago
I have a couple things I need schooling on. I've got a 1962 Williams Coquette (2 player)
1) This Match Unit is missing a coil. But can you tell me if this assembly should have a second coil and some switches. I see the credit assembly is basically the same and intact, but I don't have enough loose wires for another coil and switches here. Can anyone explain the theory behind this assembly and if it was modified for different uses? match-unit-a (resized).jpg
2) What do the numbers 0-9 (not the color codes) on the schematic under the Number Match Unit correspond to?schematic-a (resized).jpg
3) The 1st player 0-9 Drum unit has 10 wires called out on the schematic. But the drum unit itself has 15+4 wires soldered onto terminals. Any advice on how to make sense of the wires and terminals on the drum unit?schematic-b (resized).jpg
Thanks guys,
Patrick
#2 7 months ago
Here is a picture of my match unit. (1959) Williams golden bells. There should be 20+ wires. One set for the match and one set for the lights.
No second coil. It is basically a continuous stepper. (always going the same direction).
#3 7 months ago
The numbers in match unit schematic refer to backbox match feature 0-9 lamps.
Score unit has some switches (for "0" and "9" position detect and possibly EOS) and a coil besides the disc, and the extra wires go to these. Look at the corresponding score reel for player 2.
#4 7 months ago
Great info thanks. So that match unit chassis can be a one way or two way depending on the game and use. Nice to know.
For the scoring reel, I was trying to understand the schematic. I have mapped out all 3 switches and coil on the reel, but having trouble putting it together with the schematic. The trouble is the schematic does not treat the switches, coils and terminals on this unit as a single unit. Stuff is spread out and I was hoping I'd just misunderstood the schematic.
#5 7 months ago
It is easier to draw the schematic with logical functions, than trying to keep all the connections in one unit together. In later Williams games, there was a section in the manual, that described every relay and unit by their switches. But in 1962 they only included the schematic.
Score drum unit switches were usually labeled in 60's schematics as "0-9 EOS SW", "0-9 ZERO SW" and "9 D.U". Try finding the 10 point relay coil in schematic and see what energizes it. The relay of course will operate when any 10 point switch in playfield closes, but also when 1 point is scored and the 0-9 drum is at 9.
It takes a while to get familiar with EM operation and schematics, but you will get there. Good luck!
$ 86.95
$ 14.95
Pin Monk
Professor Pinball
$ 5,799.00
Gulf Coast Pinball, LLC
$ 269.00
Displays
Boston Pinball Company
$ 48.00
$ 114.95
$ 99.99
Hardware
Bright Lights Pinball
$ 26.00
Yorktown Parts and Equip
$ 69.99
$ 45.00
Great American Pinball
German-Pinball-Modular
$ 26.95
€ 27.00
YOYOKOPTER MODS
$ 130.00
$ 839.00
