I putting together a 72 Gottlieb Wild Life'
Initially
Turned power on no coin switch working......No credit button working (with credits)
Manually engaged start relay worked fine, for the most part. Played a couple games
As shown in schematic here, I jumpered where the red line is thinkin the issue lies in the blue circles.
Sure enough...coin sw work and credit button works with a jumper
checked the contacts on the 2 score motor sw (circled) as well as the B2 relay (circled) cleaned contacts. Looked like all contacts were
OK. I assumed the Bounce sw (circled) is the one on the main board and the anti cheat sw (circled) is on the coin door, they are N/C and OK.
Tried it now and no start.
Went back to look at the score motor and B2 again checked for broken wire etc. Tried it again no start but all kinds of things are goin on
NO ball count one time it played
now
Score motor runs continuously with score reels manually set at zero and have to manually activate the reset bank to stop score motor
and TILT lite is on
Holy Cow
