Hi Guys,
The sound on my scared stiff is a little scratchy. I looked behind the speaker panel and found a wire just floating around (see yellow arrow). Can you tell me where this belongs? Will add pics later...lost Internet connection.
Hi Guys,
Hi. Yes, I have pix. Will post tomorrow when I get service back. Tree limb took down my cable, Internet, phone line!
connect the green wire to the rest of the green GND wires right there.
Read.... the attached NOTE ! "IMPORTANT ATTACH GROUND STRAP"
that grounds the speaker frames,
make sure your Audio pcb is firmly grounded/ screwed down, for the scratching.
Quoted from SSpinball:connect the green wire to the rest of the green GND wires right there.
Yes, that wire needs to be connected to that BB ground right next to the one already connected in your photo.
Thanks! So I should unscrew that bolt and put the red one on top of the blue one and screw it down? What's an Audio pcb? Don't forget..I know nothing. (I CAN take the glass out now!)
Quoted from spfxted:Thanks! So I should unscrew that bolt and put the red one on top of the blue one and screw it down?
Yes, that would work nicely.
LTG
Quoted from spfxted:Thanks LTG! With the wire off like that, could it be the sound problem?
I don't know. But as you move forward it is nice to keep eliminating possibles.
LTG
This page was printed from https://pinside.com/pinball/forum/topic/need-scared-stiff-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
