Toggle Switch broke internally on my Alien Poker the other night. I guess 40 years wasn't too bad a life for it.
Is this the one I need to replace it?
https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=5640-10932-00
That one should work even though it's not the original type. You can also get a DPST (double pole single throw) switch at many big box hardware stores it's a very standard type of switch.
Make sure you heat shrink or protect the exposed wiring inside the cab in some way you don't want your hand or stuff to fall down onto the exposed terminals.
Quoted from slochar:That one should work even though it's not the original type. You can also get a DPST (double pole single throw) switch at many big box hardware stores it's a very standard type of switch.
Thanks I may even have one here laying around. I was trying to get some sort of part number or other to see one on the internet. I'm going to have to do lot of moving other pins to get the glass off and playfield up and wanted to try and have the switch ready to put in.
This page was printed from https://pinside.com/pinball/forum/topic/need-power-toggle-switch-alien-poker and we tried optimising it for printing. Some page elements may have been deliberately hidden.
