You mean no juice COMING FROM the transformer? Cuz if there is no juice GOING TO the transformer, then that's your problem!
Quoted from smokey_789:You mean no juice COMING FROM the transformer? Cuz if there is no juice GOING TO the transformer, then that's your problem!
that will do it EVERY time...
Quoted from OkieArcade:There is absolutely no juice going to the transformer (Original).
Check to see if it's plugged into the wall outlet, and the switch is turned on.
Start with making sure you have good line voltage. Put your meter on the feed into the transformer, do you have 120v there?
If not, check the line voltage fuse. Check that the power switch is functional if the game has one.
Quoted from EMPins:Start with making sure you have good line voltage. Put your meter on the feed into the transformer, do you have 120v there?
Set your DMM to VAC for this.
This page was printed from https://pinside.com/pinball/forum/topic/need-parts-for-ballys-on-beam-transformer-shot and we tried optimising it for printing. Some page elements may have been deliberately hidden.
