I've got a misaligned PF on my 02/89 WMS Jokerz that appears to be missing parts at its pivot points. The black pivot bolt that goes through the left side of the cab is bent off-center and loose in it's hole which throws the playfield alignment way off when it's closed down at the lock bar. The right pivot bolt is the same way, except that it has a washer between the bracket and cab wall. I found a bushing and nut down inside the cabinet that hint they belong to this assembly. The bushing fits perfectly over the pivot bolt and inside the PF bracket slot. Can someone please provide a proper photo of how this assembly should look? I'm thinking there should be a bushing on both pivot bolts secured by washers and a lock nut to secure the bolt tightly against the cab wall. Thanks for any help!
