Hi guys, just started having some problems with my high speed.
Game was playing just fine.
The other day I decided to clean up area by the upper left red yellow and green standup targets under the ramp. I removed the plastic with the lower left red flasher cover to access the screw to remove the upper left ramp rail. The only other thing I did was remove the plastic and star posts and bulb in the RYG target area for cleaning.
I did all this with the power OFF.
When I turned the game back on, I got some strange behavior of numerous coils firing on and off.
I immediately turned it off.
When I turned it back on, it played fine again.
not sure if this is just coincidence, or something i caused
It seemed fine the rest of the time while it was on. The next morning, I had issues again, but after turning it off and back on, it started up fine.
However, the next cold start, I had issues again.
Sometimes when I turned it on it went haywire. Multiple coils firing, flashers flashing, sounds, game starts automatically (as if someone pressed the start button), tilt sound heard, displays show garbage, and probably some other stuff.
If left on while doing this, it would eventually blow a coil fuse.
All while the CPU board shows zero on its display, but no power up tone is heard.
It appeared to do this from a cold start.
If I turned it off immediately, and back on a few times it would play perfectly fine.
Also if I turned it off and back on when it has been warmed up, it continued to work fine.
Now its not even going into game over mode, so it is unplayable.
If i've left any important information out, please let me know, and ill be happy to fill in the blanks.
i know there is a lot of experience here, and if anybody has had similar issues, it could help me find the fix.
I'd also be happy to perform any test that are asked.
i have read some of the repair guides, but want to get some additional input from Pinside.
all help is appreciated!!
Thanks Pinsiders/Sparky
