I could use some help figuring out this crazy behavior I'm having. Managed to buy a PinLED driver board and have had it act super strange in either of two pins (TZ or WHO). Specifically, columns with optos in them start to malfunction. On WHO, the MPF opto stopped responding completely. On TZ, the ball launcher opto and the rest of column 2 got stuck on, along with clock minute opto 0. When I put the original driver boards back in, everything works fine again.
I measured J116 and it came in at 14.1v which I guess is fine. The original boards are 13.8v. There's not a whole lot that the driver board does I can think of other than provide the voltage, so I'm confused as to what would cause a new driver to cause columns with optos in them to go haywire. Just to eliminate the MPU, I swapped those out and it made no difference. I would think that any problems with the switch matrix would show up using either driver board, but am open to trying whatever.
